Go to Post I owe a debt, as many FIRSTers do, to the entire organization as a whole. Every team, every student, every person involved has help make FIRST what it is today. This is my Thank You. ~Anonymous - BandChick [more]
Unread 07-31-2016, 02:50 AM
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: New Mill - Help with tooling
Originally Posted by RoboChair View Post
Simple Green and water works well with rags. You ca use it on exposed metal but you need to be sure it dries and gets re-oiled after asap.
This works - but should probably point out that this rag should only be damp and not dripping wet: such that you get a film of water in places you can't oil .
WD40 and monitored doses of Evaporust have worked for me.
Be aware if you leave Evaporust on carbon steel you'll eventually get loose carbon on the surface. So don't do that. It won't harm anything but it will be dang near impossible to remove the dark spots and if you use jeans or something with a pattern that pattern will be on your machine tool for a few decades. All easily avoided by getting it off the machine in 1 hour or so.
