Go to Post Any adult can open a door. Some can give direction. A few can give leadership. These are the true mentors. This is where true success comes from. - sanddrag [more]
Unread 31-07-2016, 03:39
addis687 addis687 is offline
no team (Team)
Team Role: Webmaster
addis687 is an unknown quantity at this point
FRCSim Install - Other Linux Distro
Has anyone here gotten FRCSim/Gazebo to work with a linux distro other than ubuntu? If so, how? (Bonus if using Linux Mint)
Unread 20-08-2016, 19:58
Blasting's Avatar
Blasting Blasting is offline
"That Guy"
FRC #1225 (Gorillas)
Rookie Year: 2015
Blasting is an unknown quantity at this point
Re: FRCSim Install - Other Linux Distro
I've gotten FRCSim working on Mint before, Mint is still close enough to Ubuntu that the installation is no different with the exception of hard-coding the release version to the appropriate Ubuntu release, ie: any 17.x Mint release to "trusty".
As non-Ubuntu based distros go, installation only differs for g++ and Gazebo installation, and sometimes Eclipse.
Let me know if you would like me to elaborate some more.
Unread 20-08-2016, 20:01
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Haven't peraonly used the software you are talking about but I do know that Ubuntu can do amazing things with software. I've been experimenting with Ubuntu and I know many local robotics companies use it to code their robots, so I guess you could give Ubuntu a try if all else fails.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 29-08-2016, 21:35
solomondg solomondg is offline
FRC #2898 (Flying Hedgehogs)
Rookie Year: 2016
solomondg is an unknown quantity at this point
Gazebo's in the Arch AUR, and works on my (Arch-based) system
Unread 18-12-2016, 18:51
mrosen mrosen is offline
FRC #4915
mrosen is an unknown quantity at this point
I got it working on Linux Mint 18. Not for the faint of heart, not ready for prime time. Good start though ... maybe in 2017 ? Here's my notes. HTH.
My Environment
I’m Linux Mint 18.
Must have Java8, both the JDK itself and a version of Eclipse that support this. I’m using Neon 4.6.1. I think a lot of my problems might have been avoided had I started with this.
FRCSim on Windows?
Should be feasible but isn’t. The simulator itself is the Gazebo robot simulation environment. To communicate with Gazebo, WPI provides a few plugins. In theory you should just install Gazebo, rebuild the plugins for that version of Gazebo and off you go. In practice, there is no Windows distribution for Gazebo and efforts to build from source failed. The reference for “Install Gazebo on Windows” says “This documentation describes how to set up a workspace for trying to compile Gazebo on Windows. It does not actually work yet.”
FRCSim on Linux
The references above are an incomplete description of how to get FRCSim working on an outdated version of Gazebo (v6) that is no longer available. If you’re running the version of Ubuntu that they have, give it a shot and maybe you’ll get lucky. Otherwise, use it as a guideline. Here’s what I did:
Install Gazebo using ‘apt’
Install the FRC C++ toolchain so that you can rebuild the plugins: https://launchpad.net/~wpilib/+archi...ntu/toolchain/ . this turns out to be not as easy as you would hope (ref: https://www.chiefdelphi.com/forums/s....php?t=141395).
Rebuild the plugins for the version of Gazebo you installed (v7 at this writing) and copy them into the simulation directory
Building WPILibJ / WPILibJSim
When you install the WPILib plugins for Eclipse, you get WPILibJ.jar which is the runtime that works on the Roborio HW. To run in the simulator you need the WPILibJSimulator.jar file which you need to build from source b/c (a) we need to upgrade the references to Gazebo 6 to Gazebo 7 and (b) there are classes missing (they’re in WPILib.jar but not WPILibJSimulator.jar) and we need to add them. Here’s what to do:
Install Gradle. This is what they use to build the library: sudo apt install gradle
Clone the repository (git://github.com/wpilibsuite/allwpilib.git)
cd into the directory it just created “allwpilib” and build it using gradle with the switch to build the simulation library also:
/gradlew build -PmakeSim
Verify the following:
/home/msr/allwpilib/simulation (note the install script and the install_resources dir)
/home/msr/allwpilib/build/install/simulation (plugins for your version of Gazebo)
/home/msr/allwpilib/wpilibj/build/libs (the simulation library itself)
So, now it’s built but we need to install it. Here’s what I do: Get the original zip archive (for Gazebo6) and unzip it into “wpilib/simulation” (which you’ll need to create -- it’s part of their install script). This includes some scripts like “frcsim” and “sim_ds” which you’ll need. But you’ll need to replace the binaries that reference the old version of Gazebo, so copy /home/msr/allwpilib/build/install/simulation into your new simulation directory and overwrite any conflicts.
You’ll also need the models that go into Gazebo. These are referenced from the manual instructions (ref above) and for convenience, here. Put them in the wpilib/simulations directory
