Go to Post FIRST, in itself, will not make you an engineer. - RogerR [more]
Unread 21-07-2016, 22:05
GoldenGollem's Avatar
GoldenGollem GoldenGollem is offline
Java Programmer
FRC #2509 (Hutchinson Tigerbots)
Rookie Year: 2015
GoldenGollem is an unknown quantity at this point
Lightbulb 2 Cameras in Java
Hello World,
As my team has been working this off season we were wondering if we would be able to use two USB cameras on our robot. We know that it is legal but we were wondering on the coding side what it would take. We are not able to test the code on the actual robot so, we only have theory to go on. Anyway, in theory this is all that should be needed to run two usb cameras at the same time on the Java SmartDashboard.
public class Robot extends IterativeRobot {
    CameraServer server;
    CameraServer server2;
    public void robotInit() {
    	RobotMap.init();
    	        //This is for the USB Camera
    	server = CameraServer.getInstance();
    	server.setQuality(50);
    	       //Replace cam0 with acutal name
    	server.startAutomaticCapture("cam0");
        server2 = CameraServer.getInstance();
        server2.setQuality(50);
               //Replace cam1 with actual name
        server2.startAutomaticCapture("cam1");
Unread 22-07-2016, 09:03
euhlmann's Avatar
euhlmann euhlmann is online now
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: 2 Cameras in Java
CameraServer.getInstance(), as the name implies, returns a singleton instance of CameraServer. That means server1 and server2 are the same in your code.
Here's how you might get both camera feeds into a single frame
// init
USBCamera cam0 = new USBCamera("cam0");
USBCamera cam1 = new USBCamera("cam1");
Image cam0Image = NIVision.imaqCreateImage(ImageType.IMAGE_RGB, 0);
Image cam1Image = NIVision.imaqCreateImage(ImageType.IMAGE_RGB, 0);
Image combinedImage = NIVision.imaqCreateImage(ImageType.IMAGE_RGB, 0);
cam0.openCamera();
cam1.openCamera();
cam0.startCapture();
cam1.startCapture();
// on each iteration
cam0.getImage(cam0Image);
cam1.getImage(cam1Image);
GetImageSizeResult cam0Size = NIVision.imaqGetImageSize(cam0Image);
GetImageSizeResult cam1Size = NIVision.imaqGetImageSize(cam1Image);
NIVision.imaqCopyRect(combinedImage, cam0Image, new Rect(0, 0, cam0Size.width, cam0Size.height), new Point(0, 0));
NIVision.imaqCopyRect(combinedImage, cam1Image, new Rect(0, 0, cam1Size.width, cam1Size.height), new Point(cam0Size.width, 0));
CameraServer.getInstance().setImage(combinedImage);
Disclaimer: untested, but you get the idea
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 22-07-2016, 14:28
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I was not involved with programming this year, but from my conversations with the programming mentors and students, I understand that we had difficulty using two cameras on the same USB bus. This problem appeared not to be java-specific, but a USB camera issue. It seems that most USB cameras (and all of the ones we had on hand at that time, including some KoP cameras) grab something like 60% of the USB bandwidth when they start up. Running two cameras without taking pains to limit these allocations, you are certain to have trouble. If you can't find any detail on how to do this online, PM me and I'll contact the mentors to find out how we resolved/mitigated the issue.
Unread 22-07-2016, 19:09
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
We ran with 3 cameras on our robot this year (front high view, front ball intake, and the reverse-cam). What we did was to extend the CameraServer class to allow us to switch feeds from one cam to another. We found that getting 2 simultaneous feeds put us a bit too close to the bandwidth cap, even at low-ish resolution (mjpeg isn't that efficient).
On our DS we had two buttons that would set the direction of travel forward and pick one of the two forward cams, and a third button that would invert the direction of travel of the robot and bring up the "reverse" cam. It was fairly efficient, and good for intaking a boulder against the rail or in the corners.
Our USB problem wasn't bandwidth (we stopped image capture as we switched cams), but that we had 3 identical cams on the USB bus -- which cam was "usb0" tended to change with each cold start of the RoboRIO. Part of our pre-match on-field setup was defining which "usbX" camera was which.
Unread 22-07-2016, 20:12
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
We has trouble with one camera on one port and two via a hub -- only one camera from the hub would be recognized. How did you guys get 3 cameras working?
Unread 22-07-2016, 23:18
bdaroz's Avatar
Programming Mentor
Rookie Year: 2016
To be honest, we used a small cheap unpowered hub and some older cameras, plugged in and they all just showed up -- they just didn't always appear in the same order.
Is there a chance the cameras and hub are drawing too much voltage?
(And I presume the trouble you are talking about means not all the cameras were being listed on the RoboRio web interface.)
Unread 23-07-2016, 10:19
Java Programmer
Rookie Year: 2015
Thanks for that info. What we will most likely end up doing is having two cameras but only streaming one at a time to the dashboard. This is the latest version of code that we have for it.(FYI this was in a command format but was changed for simplicity of this site)
Cameras cameras;
    	Cameras.cam = "";
    	server.startAutomaticCapture(Cameras.cam);
    	while(isEnabled()){
//There is a joystick button once pressed it will activate this command SwitchCams
public void SwitchCams() {
        if(Cameras.cam == "cam0"){
    		Cameras.cam = "cam1";
    	}else if(Cameras.cam == "cam1"){
    		Cameras.cam = "0";
    		//Leave following if statement equal to blank
    	}else if(Cameras.cam == "")
    		Cameras.cam = "cam0";
GoldenGollem -Hutchinson Tigerbots 2509
2015 - Mini-MN Regional 2nd Place Finalist
2016 - Mini-MN Regional 1st Place Finalist
Unread 23-07-2016, 13:25
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Yep, it wouldn't show up on the web interface. We checked with a hub that measures current draw and it looked ok. I guess we should try with a powered hub though.
Unread 23-07-2016, 14:47
bdaroz's Avatar
Programming Mentor
Rookie Year: 2016
The problem is that the native WPILib CameraServer class doesn't have a way to stop, or switch, or restart the server instance. You'll need to extend/replace that CameraServer class to make it work. Here's what we ended up doing, albeit a bit quick and dirty:
https://github.com/FRC5881/2016Robot...eraServer.java
Keep in mind that USB is designed to not overdraw current... If you have 500ma of power available and plug in (2) 400ma devices, your hub will only draw a bit over 400ma (a little for itself) and leave the other device unpowered.
You should also be able to plug those cameras into a PC and check the USB device info (lsusb on linux, for example) to see what the current required for each is. After that, some simple math would tell you if you're over committing.
One other question -- are both of these cameras identical?
Unread 23-07-2016, 17:20
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
No, we have a USB hub with a small LCD screen that displays current draw on it, and it looked ok. IIRC the power light was lit for all 3 cameras.
Two of the cameras were identical, one was a different model with a wider field of view. They were all Logitech webcams
Unread 23-07-2016, 20:46
bdaroz's Avatar
Programming Mentor
Rookie Year: 2016
I'm going to presume it was not the odd camera out that is the problem -- and that if you plug them in one at a time to the Rio they do show up on the Web Interface.
If each camera works independant of the other two, then it's not compatibility. That leaves the hub (or it's cable), and power as the likely culprits. Aside from testing with another hub (powered and/or unpowered) I'm not sure what else to suggest....
Unread 02-08-2016, 10:00
Team2895's Avatar
Team2895 Team2895 is offline
FRC #2895 (Blazenbotz)
Team2895 is an unknown quantity at this point
You guys can look at our code we had 2 cameras working but you have to manually switch over the stream as it is impossible to stream both cameras at the same time here is our code: https://github.com/Team2895/Team2895...bot/Robot.java
Sent from my iPhone using Tapatalk
Unread 03-08-2016, 00:10
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
USB bandwidth? There is no problem with running two cameras at a time, in regards to the roborio.
