Go to Post We want people to exercise Gracious Professionalism® and play at their best, but also not really because we find this archaic rule to satisfy something related to inspiring students to pursue careers in science and technology.™ - PayneTrain [more]
Unread 08-02-2016, 12:32 PM
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Re: pic: Another Swerve
What is the reduction and fps on that? It appears to be quite zippy, given that I can only see two reductions, neither of which are very extreme.
Unread 08-02-2016, 01:13 PM
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Originally Posted by ratdude747 View Post
Looks a bit hollow... You'll want a belly pan or the like to stiffen the frame (otherwise you'll have a lot of flex).
Yeah, I plan to add one in the end.
Originally Posted by marshall View Post
Is there a speed encoder on there? I see one for turning... which i think is 1:1.
Source files? This looks cool.
Yeah, theres a versa planetary encoder for the turning. Haven't added the drive encoders. I was only a couple hours into this.
Ill upload this to grabcad later on. Thanks.
Originally Posted by cad321 View Post
That lightening pattern on the gearboxes look a little too pocketed to me. I'd probably add a little more meat to them there. Aside from that I like it. And as ratdude said, you'll want a belly pan for added rigidity.
Originally Posted by asid61 View Post
The gearbox pattern might be a little too much, but given the layout it's probably not fatal. The main thing I would do with that is make the webs going to the big pivot larger (5/16" or even 3/8" wide).
The chassis looks fine to my eyes. The pattern is similar to 971's patterns this year, and didn't decrease stiffness noticeable last time I checked in simulation. Given the large square shape, however, adding a wooden bellypan would be to your advantage.
Agreed
Originally Posted by Basel A View Post
I would be concerned about having the CIM there so near to the ground. In a game with some field obstacles, you could probably rearrange a couple things and move the CIM to the top plate (through the bottom plate). There are several disadvantages (higher CG, cantilevered gears, etc.), but could be necessary.
This is designed to be an offseason project, so this is assuming a flat field, like in 2014.
Its 1:3.333 with a 3.25 OD wheel. Aroud 18 fps according to JVN's calculator. This is designed for an offseason project, so it wont weight more than 45-50 lbs. I might slow it down a bit later on.
