Go to Post Of course, someone who can score on all rack levels while hovering autononmously 12 inches off the floor in his own home zone could probably have posted on CD while winning a regional.;) - Richard Wallace [more]
Unread 02-08-2016, 16:23
Billfred's Avatar
Billfred Billfred is online now
Re: pic: 716 ouput shaft
Originally Posted by ratdude747 View Post
The funny thing is that most/all of the older AM designs are mass-produced versions of 45's gearboxes... I hear before AM while there were KOP gearboxes they generally were junk in comparison. Hence why for many teams it was worth the little bit of machining to modify a dewalt or a lot of machining to DIY gearboxes.
Now days, it's more of an art than a necessity... although the summer/fall CAD threads show that people still think about it even if they don't always execute.
Hi, old-timer turned AndyMark employee.
The 2004 kit drivetrain is the only pre-modern "kit drivetrain" I got to experience. I emphasize the quotes, because the setup using Bosch drill gearboxes and custom unobtanium mounts and couplers left a lot to be desired. (Oh, and they expected you to weld the frame.)
The 2005-2006 kit drivetrain was a sheetmetal frame designed by a college student (John V-Neun, you might've heard of him) with a single-speed gearbox designed by Paul Copioli (you might've heard of him too). This was the first time you could order all the parts online in a non-obnoxious manner, through IFI Robotics. (The internal spur gears were sourced from an upstart company in Indiana called AndyMark.) The molded hubs on this drive system that clamped around the kit Skyway wheels (remember those?) established the 1.875" bolt circle as a de facto standard for FRC that remains today. (The cast housing and metric-sized output shaft on the gearbox? Not so much.) I don't remember when the original AM Toughbox came out, but I know we were evaluating it during the 2006 season. It became part of the Kit of Parts in 2009 and 2010.
But yes, the original AM Shifter does trace its lineage back to designs introduced by the TechnoKats. Many of the shifting parts have carried over to successive designs, even as things like external output shafts, servo shifting, room for more motors, and encoders have been added.
Unread 02-08-2016, 16:43
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Not to threadjack, but...
"skid plates"!? And that was a mere 12 years ago. It's incredible how far FRC has come.
Unread 02-08-2016, 16:51
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The 2004 setup was significantly less crappy than the 2003 one as well.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-08-2016, 16:53
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
real skid-steer
Unread 02-08-2016, 18:24
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
For a team wiyhout hex broaching abilities but with a lathe + mill a square shaft for some applications isn't a bad idea. I'll definitely keep this in mind.
Unread 02-08-2016, 18:30
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Keep in mind you would probably want a square broach for the dog, however. You might be able to get the dog 3d printed in steel.
Unread 02-08-2016, 20:44
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Depending on where you are, wire EDM + post machining might be a cheaper and quicker option than metal Additive. But if you go that route, you might as well go hex.
Unread 02-08-2016, 20:19
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Yeah I should have clarified that I was mainly speaking of the AM shifter... as I among many others know the former technokat that designed it as a student on 45.
The tough box came out in 2008 KOP. 2007 had the same setup as 2006. I thought they were AM gearboxes because of common gears... I was obviously wrong.
Unread 02-08-2016, 21:15
Billfred's Avatar
2007 did not have the same gearbox as any other year. That was the year of the BaneBots 56mm gearbox, which in as-shipped-in-the-kit form was not remotely ready for the task of playing a very physical game like Rack 'N Roll. (Whether they were ready after the fixes that went out was a rather subjective matter that depended on your application.)
You are correct that the Toughbox first entered the kit in 2008. We used SuperShifters that year on 1618, so those sat off to the side.
Unread 02-08-2016, 21:25
ratdude747's Avatar
AKA: Larry Bolan
That's interesting. On 1747 as a freshman in 2008 I remember finding 4 old KOP gearboxes cases made of cast metal; their rookie year was 2006 and they at that point had never used stock gearboxes (AM Shifter Gen2's in 2006 and 2007). Thus it made sense for 2 to be 2006 and 2 to be 2007. I hadn't even heard of Banebots doing KOP gearboxes although given the era I could see them being awful (chipped gear city)... My guess is two of the castings must have been 2005 ones that were "gifted" by 461 when the team was founded.
Sorry for the misinformation.
