#76
Re: Math Quiz 9
Some warmup questions to this if you can't figure out where to start:
OBTW, with proper scaling, Greg's answer for the 100000-gon of area 1 provides an answer to the original problem good to within 1 part per 10,000: And, OBTW2: if you can find the closed form, each of the four questions can be calculated in fewer than 10 keystrokes on a calculator with the following buttons: Quote:
#77
Re: Math Quiz 9
I have posted this figure which I created to describe variables in my calculation of the length of the average line segment from a point on the edge of a circle to a point on the interior. I used this, or a very similar coordinate system, to solve all the "circle questions" except for the one about the mean square of the segments. I am also confident that the same questions can be answered for the sphere using a similar point of view.
#78
Re: Math Quiz 9
I did the integral for the average length of a line segment within a sphere, and found that the answer is rational! This problem was actually simpler to integrate (though just a bit trickier to set up) than any of the two-dimensional problems. If no one posts anything (yes, even a "hold on, I'm working it!") on the circle or sphere questions by Wednesday at 1800 US-CDT, I'll post my solutions so we can close out these quiz questions.
#79
Re: Math Quiz 9
0.9525383819936485
Sample size: 60 million |
#80
Re: Math Quiz 9
Post your code and we'll show you where you went wrong.
#81
Re: Math Quiz 9
Re: Math Quiz 9
Yes, as well as the intermediate case where one endpoint is on the sphere and the other is internal. I don't recall whether the mean square length was rational or not; I'll check this evening.
#83
Re: Math Quiz 9
Re: Math Quiz 9
I was referring to both endpoints in the volume, but I see that for all three cases (both exterior, one exterior, both interior), the mean length as well as the mean square length are all rational.
Given AM's interest, I will hold off until at least Friday at 6pm to post solutions. When posting a candidate solution, please show your work, and specify whether you are solving for:
#85
Re: Math Quiz 9
A Monte Carlo simulation written in python and running on my laptop isn't a great solution if 1 part in a million accuracy is required, but since I had essentially already written the program, I figured that I might as well give it a shot. For the average length of line segments in the interior of an r=1 circle, I got 0.9054124568 after 4e10 trials. I'm not certain whether or not this meets the accuracy requirement. I also made minor modifications so that I could simulate the chord problem, and I got 1.2732310914 after 7e09 trials. This problem requires far fewer trials to get an accurate result and I believe this solution meets the accuracy spec. I can post my code if anyone is interested.
#86
Re: Math Quiz 9
Wrong by ~3 ppm.
Re: Math Quiz 9
1) How long did 4e10 trials take to run?
2) Yes, please post your code. edit: 3) What's the period of the PRNG you used? Last edited by Ether : 07-08-2016 at 17:13. |
#88
Re: Math Quiz 9
About 16 hours. My laptop has an Intel Core i7-6700HQ Quad Core and I ran 4 copies of my program at once instead of implementing multithreading. This seemed to work as desired based on the cpu usage and left me with enough overhead to not impact my normal computer use.
Internal points code: Code:
import numpy as np
import time
def genPt(r_cir):
r = r_cir*(np.random.random()**0.5) #Square root correction ensures even probability distribution over area
theta = 2*np.pi*np.random.random()
x = r*np.cos(theta)
y = r*np.sin(theta)
return x,y
t = time.time()
trials = 10**9
r = 1.0
total = 0.0
for i in range(trials):
x1,y1 = genPt(r)
x2,y2 = genPt(r)
total += ((x2-x1)**2 + (y2-y1)**2)**0.5
if not i%10**7:
print(i)
print(total/(i+1))
print('')
print(total/trials)
print(time.time()-t)
import numpy as np
import time
t = time.time()
trials = 10**10 #Number of random samples
total = 0.0
r = 1.0
x1,y1 = 0.0,r
x2 = r*np.cos(theta)
y2 = r*np.sin(theta)
if not i%10**7:
print(i)
print(total/(i+1))
print('')
print(total/trials)
.I used numpy.random.random(), which uses the Mersenne Twister sequence and has a period of 2^19937 − 1. Unfortunately I wasn't able to run quite that many trials. |
#89
Re: Math Quiz 9
Re: Math Quiz 9
Greg, try this for the internal points problem: taking advantage of symmetry, generate 2 random points in Quadrant1, then reflect one of the points into Quadrants 2 thru 4 so you get 4 lengths per iteration. Then you can use 4 times fewer iterations. Also, doing this allows you to significantly optimize the code to eliminate a lot of repetitious floating point operations. I think you'll find that approach to be much faster. I was able to get 1 ppm accuracy in 7 minutes of runtime on a 10-year-old Pentium D desktop machine (using 32 bit compiled code). Here's the pseudocode for it: Code:
pio2=pi/2; // initialize constant // iterate: r1=random; r2=random; dq=pio2*(random-random); tmp1=r1+r2; tmp2=2*sqrt(r1*r2); cosdq=cos(dq); sindq=sin(dq); sum += sqrt(tmp1-tmp2*cosdq) + sqrt(tmp1+tmp2*sindq) + sqrt(tmp1+tmp2*cosdq) + sqrt(tmp1-tmp2*sindq); // don't forget to divide by 4*iterations when done iterating Using symmetry for the chords problem, you can reduce the length computation to: Code:
sum += sin(pi*abs(random-random)); Last edited by Ether : 09-08-2016 at 15:47. |
