Go to Post If the fan club goes away, or isn't always right in your face doing things the public sees, does that mean the reason for the fan club is gone? Nope. - Elgin Clock [more]
Unread 02-08-2016, 22:02
joeojazz joeojazz is offline
FRC #5712
joeojazz is an unknown quantity at this point
Visual Studio
Our team wants to switch to c++ and program in Visual Studio we where wondering if it is possible to program and deploy code to the robo-rio from Visual Studio. We have found c sharp templates to deploy from Visual Studio but not a c++ one.
Unread 02-08-2016, 22:37
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: Visual Studio
I'll bite... why Visual Studio?
Unread 02-08-2016, 23:50
balloman balloman is offline
Sophomore Programmer
AKA: Bernard
FRC #0034 (Rockets)
Rookie Year: 2016
balloman is on a distinguished road
Re: Visual Studio
I assume because of how nice it is to code in Visual Studio
Unread 03-08-2016, 00:02
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
Re: Visual Studio
The Visual Studio compiler is much more powerful and easier to use... well easier for someone who uses it professionally on a daily basis.
Maybe I'm bias, but it has been so much preferred that we went through the trouble of writing all the code simulated in visual studio environment, and then porting it over later. As debugging remotely is a real nightmare and 10x more time consuming (that 10x is a conservative estimate, probably more time considering all the times we had to redeploy code).
Last I checked, visual studio 2013 and above can have an Arduino IDE environment, but I've never tested that yet. It could work, but then the trick would be to get WPI libraries built as well... or link to them from VS. I think it can be done, but I haven't really had a chance to pursue this.
Unread 03-08-2016, 00:20
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
Re: Visual Studio
If you want to get the code to work nicely with Visual Studio, you're going to have to do a bit of manual work.
Step 1: Get the WPILib and NT-Core header files. These will usually be under ~/wpilib
You can add these to your project's header files include directory. This should fix up any false-alarm syntax errors you might be getting.
Step 2: Configure your build system.
This is a bit difficult. First, you need the FRC C++ toolchain installed and added to your PATH.
Next, you have to use some form of build system to send over and compile your code. You can use the one provided by WPILib for this.
WPILib uses ANT to build and deploy code. Visual Studio supports ANT builds and you can find instructions here. Reconfigure your build targets to use this build system, and you should be set to go. If you're stuck looking for what tasks to run, run a simple build in eclipse and take note of what tasks are executed, that should help you.
Keep in mind this is only to build and deploy code. The code you build will not run on your system, as it's built for an ARM target (the roborio)
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 03-08-2016, 07:26
marshall's Avatar
Re: Visual Studio
I had no idea Visual Studio was a compiler.
That's sarcasm folks, calm down. For the record, I work in a plethora of development environments as well as compilers as a professional on a daily basis. They are all equally crap, except for VIM, which isn't technically an IDE but there are enough enhancements to it these days that I count it as one.
Unread 03-08-2016, 07:40
Jaci's Avatar
Rookie Year: 2015
Re: Visual Studio
Visual Studio isn't a compiler, but MSVC is
I think the main attraction to Visual Studio is just how $@#$@#$@#$@# good IntelliSense is. The only system I've seen come close is JetBrains' code completion, but IntelliSense still tops it IMHO.
Jacinta R
OpenRIO : Owner
Unread 03-08-2016, 07:50
marshall's Avatar
Re: Visual Studio
It does have some perks. If I were writing in a consistent language then I could see where that would be very useful. I've been using VS lately with some work in Unity and on the CTRE HERO board.
Unread 03-08-2016, 11:30
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Visual Studio
...I think the main attraction to Visual Studio is just how $@#$@#$@#$@# good IntelliSense is...
+1 this.
Unread 03-08-2016, 11:57
JamesTerm's Avatar
Terminator
AKA: James Killian
Re: Visual Studio
Yes, Visual Studio Compiler...
That's my wording and I'm sticking with it!
Also... in your critique of Visual Studio... did you try it with the Visual Assist plugin? This really makes a difference.
Unread 03-08-2016, 13:06
ahaltom ahaltom is offline
FRC #5712
ahaltom is a glorious beacon of lightahaltom is a glorious beacon of lightahaltom is a glorious beacon of lightahaltom is a glorious beacon of lightahaltom is a glorious beacon of light
Re: Visual Studio
Thanks for the reply, Jaci! It's great to see that someone has worked with robot code in Visual Studio. I've used Visual Studio a TON in college, so it really appeals to me more than Eclipse does (IntelliSense is amazing). I'll work with Joeojazz and try to get Visual Studio working properly. You may hear from Team 5712 in the next few days if we hit any bumps in the road, but we'll give it a shot!
Alex
Team 5712 Mentor
Unread 03-08-2016, 13:33
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is online now
John Rangel
FRC #0842 (Falcon Robotics)
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
Re: Visual Studio
If you are interested in using C#, RobotDotNet seems to be a pretty solid solution: https://www.chiefdelphi.com/forums/s...d.php?t=140972
2011-2014 Arizona Regional Winners
2012 Dean's List Winner
2012-2013 Team President
2013 8th Place Robosub Competition
2014-? Mentor
Unread 04-08-2016, 00:16
marshall's Avatar
Re: Visual Studio
I am by no means a critic, just a cynic. I'll check out the plugin though. Always open to new stuff.
Unread 04-08-2016, 09:03
JamesTerm's Avatar
Terminator
AKA: James Killian
Re: Visual Studio
For reference:
http://www.wholetomato.com/
I've been using this since around 2002... (It works on all versions of visual studio)
