Go to Post You worry about your team. Let other people worry about their own teams. - pfreivald [more]
Unread 06-08-2016, 16:18
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Re: Python Socket Between Devices
Like I said, give your Pi a static IP address, or just replace 10.TE.AM.XX with raspberrypi.local.
That will definitely be an issue. You're right, putting bind() back in the client will fix it. Here's my code that I tested this with. Uses python 3, so might be a little different than yours.
Client
import socket
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind(('', 5800))  # Bind to empty IP so it can use anything
s.connect(("192.168.1.3", 5800))  # 192.168.1.3 is the IP of my server
s.send(b"hello")
s.close()
Server
import socket
serversocket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
serversocket.bind(('', 5800))  # Again, bind to any address, but this specific port
# become a server socket
serversocket.listen(1)
(client, addr) = serversocket.accept()
print("Recieved connection from {}".format(addr))
while True:
    data = client.recv(1024)
    if len(data) == 0:  # According to the spec, empty recieve means that the socket is closing
        break
    print("recv {}".format(data))
client.close()
According to Wireshark, this code only communicates on port 5800.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 06-08-2016, 17:56
Technologyman00's Avatar
Technologyman00 Technologyman00 is offline
AKA: Collin
FRC #1792 (Round Table Robotics)
Rookie Year: 2015
Technologyman00 is an unknown quantity at this point
Thank you So Much for All of your help everything works great now!
