Go to Post Ahh! I see that you discovered the "CMD_FLING_RECEIVER_RADIO_ACROSS_ROOM" command in the robot scripting language! Nicely done! - dlavery [more]
Unread 07-08-2016, 11:17
ctt956 ctt956 is online now
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: Non-FIRST Motor Suggestions?
This doesn't need to go fast; probably not faster than 5 MPH(7.33 FPS). It would need the ability to drive on most surfaces, but it would mostly be driving on concrete, asphalt, and maybe dirt, grass, or gravel. Hill climbing ability is important, and so is weight pushing and pulling. The low speed should allow for high torque gearing. I checked wheelchair motors, and they seem to be on the expensive side. I considered CIMs, but I'm not sure if they could handle this much weight. Could they run at 24 volts? The runtime would vary, but the battery would limit it. It would mostly be fairly short though.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
