Go to Post But seriously? White paper.. CD.. upload.. You get what I'm sayin'! :) - Elgin Clock [more]
Unread 05-08-2016, 14:40
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: New Mill - Help with tooling
Originally Posted by matthewdenny View Post
So lets say I have a 3/8" carbide end mill. Do I just place it in the 3/8" B&S Collet and start milling?
What about a 3/8" Drill bit?
Link to collet set: http://littlemachineshop.com/product...ProductID=3011
Place it in the collet, stick it in the spindle, tighten the drawbar, and then you're good to go.
For drill bits, it varies. For fractional sizes that you own the collet for, you can use the collet. Otherwise you'll need to use the drill chuck.
Unread 07-08-2016, 19:51
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Sorry for all the questions, you all have been great. But I have one more (for the moment).
So I can't find a face mill that will fit our mill taper. Can I get a face cutter that mounts to an arbor with a straight shaft and put it in a collet?
Unread 07-08-2016, 20:29
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
You can do that, but it might be easier to find a face mill arbor and face mill separately. If you can't, then collet is fine as long as you don't take huge heavy cuts.
Unread 07-08-2016, 22:24
FRC #6054 (Dukes)
I was looking at facemill arbors, but couldn't find any with a B&S #9 taper. Or am I thinking about this the wrong way?
Unread 07-08-2016, 22:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
First of all, have you actually verified that is the taper of this mill? From what I've read, it was available with a variety of spindle tapers.
Unread 07-08-2016, 22:59
FRC #6054 (Dukes)
No I haven't had the opportunity to yet. The B&S 9 seems the most common from what I've read. And with the short window between getting the mill and having to order tooling, thats what I'm spending my effort preparing for. The other options seem much more common, and if it would be fortunately one of these, I think i could find parts in a day or two.
