Go to Post Fans come and go... but if you're a diehard, you stick around during the losing seasons, too. - Amanda Morrison [more]
Unread 07-08-2016, 22:28
IanM IanM is offline
FRC #5690 (SubZero Robotics)
Team Role: Student
Rookie Year: 2015
IanM is an unknown quantity at this point
Re: COR Robotics and Subzero T-Shirt Cannon!
Originally Posted by asid61 View Post
Looks great! That range is nothing to scoff at for sure. It could use some decorations though.
4 shots isn't much... you should think about stocking extra tanks or using a larger air tank or something.
It actually gets more than 4 shots. If the tank is filled up to around 110 psi we get 4 long shots. After this the psi is still around 60 which allows for around 5 more mid range shots. For the parade we recently had it in we only need to pressurize the tank a couple of times during the mile long parade.
Unread 08-08-2016, 09:39
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
You can also probably get a lot more shots by lowering the time the solenoid is open for when you don't need 100 feet. We had a 5 gal tank @ ~120 psi that fed through a regulator into a 1 gal tank @ ~60 psi and we were able to get 8-10 shots at >50 ft (not even completely optimized) before dropping below 60 psi in the main tank. By my calculations, your tank is ~ 9 gal, so you easily have the energy to get well over 10 good shots, it's just about how efficiently you use it.
Unread 08-08-2016, 21:22
Team Role: Student
Rookie Year: 2015
Smile Re: COR Robotics and Subzero T-Shirt Cannon!
Right now we haven't done anything with controlling the solenoid. its controlled with how long you hold the button. A really quick tap is all we use to fire at the moment. Later on we will hopefully be adding a way to control the amount of time the solenoid is open. This robot will be going through many changes as we learn and experiment with it!
Unread 11-08-2016, 03:46
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
@Ginger Power
Do you have a website for COR? This would be a great place to post it Just saying!
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 11-08-2016, 10:51
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Originally Posted by Chief Hedgehog View Post
@Ginger Power
Technically there's a website, but it's such a work in progress that there's almost no reason to post a link. Here it is anyways.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns 2015/2016 Project Lead: Reveal Paper
