Go to Post There's no better way to start your FIRST career then opening a box and getting free stuff from Andy Baker! - JosephC [more]
Unread 08-08-2016, 11:52
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
Re: LED RGB Lighting
This year, we used Adafruit APA102 DotStar LED strips controlled off the SPI on the RIO. Incidentally, I'd prefer to use an external device (probably arduino) to not soak up processor time on something which probably isn't as important as actually controlling the robot. However, if you're interested, here's our driver for those from 2016:
https://github.com/RobotCasserole173...sLEDStrip.java
Unread 08-08-2016, 13:16
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Not sure if it helps, but you can use a typical SPI to control the data line for neoPixels.
We did it for the HERO robot controller...
https://github.com/CrossTheRoadElec/...ixel%20Example
...basically just make each pixel bit a SPI byte. So if all you have is a SPI, you could get it to work.
