Go to Post Not sure if its fair to call this or not yet. Back a group of dedicated teenagers far enough into a corner, and they're gonna find a way out. - Racer26 [more]
Unread 28-07-2016, 19:02
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Use of Lithium Iron Phosphate (LiFePO4) batteries in place of Lead Acid for FRC r
Originally Posted by Mk.32 View Post
I have personally poked holes in most of them....
A123s are fairly safe, some other Lifepo4's are not as much but when they vent they vent. https://www.youtube.com/watch?v=EMARDvMz62A
The pouch types LiFepo4s also vent pretty energetically, that was what a kid at a local robot event had go off in his bit and he got a face full of lithium smoke (And this was like a tiny 2AH 12v pack).
Sure LiFepo4 it's much safer then LiPo but I still wouldn't trust high school kids with them.
That just looks like a bit of toxic smoke... compared to the fiery conflagrations of LiPO I think LiFePO4 is still way safer.
Especially in the SLA "packaging" like in the OP's link, I would find it hard pressed to kill one.
Unread 28-07-2016, 19:08
AdamHeard's Avatar
Lead Mentor
You do realize SLA will also potentially energetically vent when punctured?
Few battery chemistries will let you store significant energy and be happy when you dead short them internally (and SLA isn't one of them).
Unread 28-07-2016, 19:10
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
The types of battery OP linked has internal protections and a fuse (in this case a 25amp internal one) that keeps it pretty safe.
Like i said LiFepo4 is safer then LiPo but I still wouldn't trust high school kids with ones without a built in BMS/etc. And I don't now of any pre-made packs 12v 10-15ah that can handle the 200amp burst current FRC demands for a reasonable price.
The A123 packs I've put together/the ones you generally find in battlebots (like tombstone) are just raw cells wired together connected to whatever. Would not trust students with these.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 28-07-2016, 21:10
MecaNaught's Avatar
MecaNaught MecaNaught is offline
Automation Engineer
FRC #3102 (Tech-No-Tigers)
MecaNaught is on a distinguished road
Wow, this thread got a lot more attention than I thought it would. Thank you all for your replies.
The biggest reason I see here that it wouldn't work is the 20A max output.
I do know that lithium batteries of all types are more hazardous due to their ability to rupture and spill out toxic fumes. However, lipo4 (supposedly) is a much safer chemistry. Combine that with good physical and circuit protections, I think these batteries would be usable for teams that know what they are.
The main reasons I wanted to use this battery was for better consistency with charges, lifetime, consistent output over the duration of the output, and it'd be a nice piece. I see now though that there is atleast one major drawback that prevents them from being used in FRC bots.
Someday I hope there are better batteries FRC can recommend, because we go through a lot of lead acid batteries every year, and it seems to be quite hit or miss if they'l keep their charge over time. One of our big things in competition is making sure the battery we put on our robot has the highest charge, because many shooting/throwing mechanisms will change depending upon the charge of a battery.
Unread 28-07-2016, 21:18
MecaNaught's Avatar
Automation Engineer
snip
I really appreciate the time and effort you put into that reply, it gives some very good insight into and otherwise mysterious world of batteries.
Are there any batteries you would recommend for offseason use where the Amp-hour rule doesn't apply? Just a higher Ah battery of the same type or is there anything better?
Unread 28-07-2016, 22:14
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by adciv View Post
To play the other side....
Between not just longer charge life, but longer cycle life, it can be cheaper to use a lithium over the legal SLABs. Yes they can cost several times more, but you aren't cycling your legal batteries as much and so they last longer. I remember one team saying they did so much off season stuff they used up 10 batteries a year. I'm not going to debate if that's due to misuse or what. Regardless, their life span is also longer and can result in long term savings to a team.
At work, we expect a SLAB to last 2 years if not heavily cycled. In FRC I have found we will get 3 or 4 seasons. At work, we expect a lithium to last 5 to 10. Even with the increased up front costs, this can yield substantial savings in the long run.
10 batteries isn't outlandish. We usually lose 4 or 5 a year, and I can remember a couple years ago when we did a lot worse. Some of the team were hot-cycling batteries to complete discharge at a week long fair demonstration without realizing what would happen. We lost around 10 that year.
Unread 30-07-2016, 10:54
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
That would seem to imply misuse then (under the way we typically call it at work). In your opinion, would you say the brownout protection on the roborio is helping to prevent battery death? I know we're replacing once it starts to trigger.
Unread 01-08-2016, 17:15
If one reads the data sheet linked above, the max shutdown current is 36 amps. Most motors draw more than that all on their own. Please remember that the current AGM battery is regularly sourcing more than 500 amps in our service.
Unread 01-08-2016, 17:18
AdamHeard's Avatar
Lead Mentor
While true for that specific pack, there are many LiFePO4 cells that can safety source such currents when assembled into the AH size we would run.
Unread 01-08-2016, 23:31
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Exactly. I've worked with LiFePO4 cells all the time when I worked in the plug-in hybrid automotive industry. These cells are intrinsically safer than other lithium chemistries.
I built multiple 40AH packs using CALB, Thundersky and some large cylindrical cells for demo robots. They work fine provided you have a BMS to monitor the cells and protect them from over charging and discharging.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 02-08-2016, 08:49
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Eh, just use a high- C rated RC car battery. 10AH would be fine. Make sure to use the hardshell.
My RC car pulls 200 or 300 amps on acceleration and they do fine. MaxAmps makes great ones but they are expensive. Charge them at 20amps if you want, they will do fine.
Make sure they have the hard case. Put a Lipo low voltage sensor on it, they are typically $5.
Never had a lipo explode or puff up. Just be cautious because they have the ability to.
Have fun
//TODO: make signature
Unread 09-08-2016, 10:51
Teams regularly exceed 500 amps on the current battery.
Unread 09-08-2016, 10:54
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Not that this has anything to do with FRC bots, but I wonder what is the current draw on a Tesla car in "Ludicrous Speed" speed mode.
Unread 09-08-2016, 11:04
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
According to Wired, 1,500 Amps.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 16-08-2016, 14:01
So we can talk apples to apples, the Tesla battery is also 375 volts.
