Go to Post Did our Jaguar swallow a chipmunk, or is something else going on? - Tom Line [more]
  #61   Spotlight this post!
Unread 19-07-2016, 21:32
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Chain vs. Belts?!?
Originally Posted by Knufire View Post
The pulleys that VEX and AM sell are 5mm pitch HTD, so that's what most FRC teams use. Usually 9mm or 15mm wide. You can also run GT2 tooth profile belts on HTD pulleys.
If you use a GT2 profile with HTD pulleys, it's not supposed to add any benefit, so generally speaking it's better to just stick with HTD for availability purposes.
The lower limit (and it's a sketchy one) for 5mm pitch 9mm wide HTD belt pulleys is 24t apparently for a typical year (read: not this year). I believe that 36t is safer than using 24t, especially if it's your first time. If you use 15mm wide belts I'm not sure, but 24t is supposed to be safe with those.
You would be better served asking "Chris is me" because I'm just parroting what he says at this point. A quick search on google should turn up some relevant threads about belt sizes.
  #62   Spotlight this post!
Unread 19-07-2016, 21:36
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by DrewMatic View Post
But back to the belts... What sizes would you recommend. I know 100% that the sizes may vary between years and robots.
We ran belt our second year (2013 Ultimate Ascent) for the lighter-duty portion of our climber, and for our frisbee feeder (or more precisely, frisbee arrestor), and in our fourth year (2015 Recycle Rush) for the drive system exactly according to the AM-14U2 plans. IIRC, all were stock 15 tpi belt.
Obviously an edit:
Originally Posted by troy_dietz View Post
I think you may have your games mixed up a bit.
Yes, RR is RR is RR. I also fixed this above...
  #63   Spotlight this post!
Unread 19-07-2016, 21:38
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz is on a distinguished road
Originally Posted by GeeTwo View Post
...(2015 Rebound Rumble)...
  #64   Spotlight this post!
Unread 20-07-2016, 01:10
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
But back to the belts... What sizes would you recommend. I know 100% that the sizes may vary between years and robots. But I'm not sure on the standard belt sizes due to the inexperience with the topic.
Others who have run custom drivetrains with belt would be able to tell you better, but the numbers Sam posted are great to start with. Though if you need to run smaller sprockets than what is recommended, you can always incorporate idler sprockets/bearings into your belt run to increase the amount of wrap you have on your pulleys. This adds weight and complexity, but it is an option.
  #65   Spotlight this post!
Unread 08-08-2016, 18:38
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
Sorry it took a bit longer than expected to get the pics but here they are. This is the chain break that we made to break #35 chain so that we could get away from using master links. The chain is aligned in the line of of holes on the bottom while a pin is pressed down with the handle. It works great for us and is really fast as it does not use any other tools at all.
ID:	20956  Click image for larger version
FRC Rebound Rumble | Ultimate Ascent | Aerial Assist | Recycle Rush | FIRST Stronghold | FIRST STEAMWORKS
FLL Senior Solutions | Nature's Fury | Trash Treck | Animal Allies
  #66   Spotlight this post!
Unread 08-08-2016, 18:41
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Lireal has a spectacular aura aboutLireal has a spectacular aura aboutLireal has a spectacular aura about
https://mail.google.com/mail/u/0/?ui...92c66_0.1& zw
https://mail.google.com/mail/u/0/?ui...d904a_0.1& zw
The links don't work right now. It looks like they are links to email attachments. Can you upload them to google drive or similar and share them that way?
  #67   Spotlight this post!
Unread 09-08-2016, 08:43
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
Fixed it, the pics are visible now.
  #68   Spotlight this post!
Unread 09-08-2016, 14:42
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
How do you assemble chain onto the robot? Or do you always create a loop of known length and wrap it around un-tensioned sprockets?
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
  #69   Spotlight this post!
Unread 09-08-2016, 18:10
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
We always just create known length loops like you said. With how much #35 stretches on something like a drive train through out a season, we find that we always need chain tensioners anyway so it really is not to big a deal.
  #70   Spotlight this post!
Unread 11-08-2016, 10:44
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
Belt vs chain, in my 4 years, relatively short compared to many of these people, I have not seen a lot of difference if the shafts the belt/chain is on are attached to the same plate, when you start getting joints in between it gets a little hairy with belts, but we have only broken a chain once, and that was on our t-shirt shooter while driving in the grass and all its drive is 25 chain, our 2012 robot, a very similar design, uses 35 chain from the gearbox to the center axle, then 25 from the center axle to the end axles and we have never had any problems. On the belt side, the past 3 years we have used belts in the drive and never experienced any issues, our 2014 bot is still running all original parts, except the wheels. 2014 and 2015 we used the standard kit base and 2016 we used a modified version of the Rhino Track system. (custom fit to our Breckoflex tracks) We have used poly cord in the past as well, the last time was 2012, but the stuff is quite useful for intakes, our 2006 robot uses a crazy pulley system and a bunch of poly cord to run the intake and spiral ball storage system off one motor. Poly cord can't take too much torque, but sometimes that is a good thing and the cord is not near as picky about alignment as long as you have deep pulleys and if needed you can even make it turn on multiple planes.
I didn't break it... this time.
  #71   Spotlight this post!
Unread 12-08-2016, 12:53
Oblarg Oblarg is offline
AKA: Eli Barnett
Some thoughts, from my personal experience:
Belts are more sensitive to C-C distance. Chain is more sensitive to alignment. I've never once, in my many years of FRC, seen a timing belt jump off a pulley (exclusively using flanged pulleys, admittedly, has helped with this). I've seen chain jump off not-quite-aligned sprockets more times than I can count. However, I've seen plenty of not-quite-tight-enough belts ratchet, whereas chain will only ratchet if it's basically falling-off-loose.
Complicating this fact for chain is the tendency to stretch, which is not a problem with belt. Once a belt is properly set up, you can forget about it. Chain, not so much.
The upshot of this is that chains will (almost) always require either tensioners or adjustability at one end of the run. On the flip side, if you don't have the machining capability do to precise C-C distances, so will belt.
Belts are much, much quieter, which is a bigger benefit than you'd think.
Chain can be put on in-place without moving a sprocket, via. masterlink. Belts cannot.
Chains can transfer a much higher maximum load, given the size of belts used in FRC. If you're limited in your pulley diameter or belt width, or if you just have a mechanism with whopping forces involved, this can matter.
This isn't rigorous at all (so take it with a grain of salt), but belts seem to be less-prone to bizarre one-off undiagnosable failures than chain. A fair number of times I've seen chain fall off drives with no visible faults, with no hint of the cause and no subsequent failures despite nothing being changed. I have seen a grand total of one belt failure in my entire time in FRC.
My teams tend to use belts, because we value reliability and belts basically never fail.
On #25 vs. #35 chain, my advice is to avoid the former unless you are certain of your team's machining precision. As I mentioned, #35 chain is already more sensitive to mis-aligned sprockets than belts - but #25 chain is *far* more sensitive than #35 chain, still. If you cannot align the sprockets extremely well, it will fail. My teams, which machine almost exclusively with a chopsaw and a drillpress, have abandoned #25 chain for this reason, and we do not regret it one bit.
"The breakfast of champions!"
  #72   Spotlight this post!
Unread 13-08-2016, 17:08
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
+1. #25 has only worked well for us when alignment was due to COTS parts, rather than our own machining. Then again, I wish we did more machining with a chop saw and a drill press; I am fighting an uphill battle against the hand drill and the Dremel tool.
  #73   Spotlight this post!
Unread 17-08-2016, 13:01
S1LK0124's Avatar
S1LK0124 S1LK0124 is offline
FRC #0234 (Cyber Blue)
Rookie Year: 2016
S1LK0124 will become famous soon enough
I know for a fact that my team has published a paper evaluation this very topic. If you'd like, I can post a link to it!
  #74   Spotlight this post!
Unread 17-08-2016, 13:03
S1LK0124's Avatar
Rookie Year: 2016
You can find it here, scroll down until you find the "Belts vs Chains presentation" PDF.
  #75   Spotlight this post!
Unread 20-08-2016, 00:27
C.Lesco's Avatar
C.Lesco C.Lesco is offline
Engineering Captain, Driver
FRC #5870 (League of Logic)
C.Lesco will become famous soon enough
Chains suck if you dont know how to instal them or get that finicky half link in however used correctly i think its fine. As for belts, a good belt is better in my opinion "but belts might stretch" people argue. Youre using the thing for 6 hours flat out total at most, it doesnt matter in the time span of build and comp unless youre using a multiyear old belt. BELLLTSSSS
Rookie Allstar winner North Bay regional 2016 [Team 5870]
Driver 2015 [Team 4814]
Lead Driver 2016 [Team 5870]
Build, Design and Engineering Captain 2016 [Team 5870]
Mentor 2017 [Team 5870]
