Go to Post If it walks like a duck, and talks like a duck could be a very clever animatronics display created by Disney Imagineers.... Sometimes it is just a duck. - IKE [more]
Unread 10-08-2016, 17:48
piazik's Avatar
piazik piazik is offline
AKA: Anthony Piascik
FRC #0364 (Team Fusion)
Team Role: Driver
piazik has a spectacular aura aboutpiazik has a spectacular aura about
Is the roboRio compatible with more than 2 cameras at the same time?
We want to use a roboRio with a side project, and want to know if it is possible to use more than two cameras. I am aware that you cannot view them at the same time, and have to toggle in between them. Also, that there are only two USB ports on the device itself. Would a USB splitter be able to use more?
Thanks
Team Fusion 364 - 2014-Present
Team Fusion Drive Team
- 2016-Present
2016: Bayou Regional - QF
Rocket City Regional - 3rd Alliance, 1st Pick, Finalists (WILD CARD)
Hopper Division - Winners
Einstein Mass - Semi-Finalists
Unread 10-08-2016, 18:21
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: Is the roboRio compatible with more than 2 cameras at the same time?
Yes a usb splitter would work. It is just a regular Linux machine so it will work. I think you can actually set up two or more streams at once using a tool called mjpeg streamer. Look it up on Chiefs Delphi.
Unread 11-08-2016, 06:39
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
You can view two cameras simultaneously. It's just the existing code provided to us doesn't support it. We have had multi camera streaming on our robot before.
Unread 18-08-2016, 02:30
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Yes multi camera works, but you'll need to roll your own solution as the libs won't work with more than one camera as-is.
One other point is to be mindful of how many you stream simultaneously, and the bandwidth required. For demo/testing purposes you'll be fine, but if you hit a competition field, you'll be rate limited to 7Mb/s.
