Go to Post They know how to make paperweights into other objects, like robot controllers. - Greg McKaskle [more]
Unread 09-02-2015, 12:07
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
Using Digital Sidecar?
Andy Mark is currently out of stock with the Rev Robotivs more board. Would we be able to use a digital side car in order to get more Digital IO ports?
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
Unread 09-02-2015, 12:24
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Using Digital Sidecar?
Potentially, yes. You'd have to figure out which pins in the ribbon cable correspond to the pins in the DSC and route those to the appropriate MXP pins. (There might still be a DSC schematic somewhere on usfirst.org.)
Note the DSC would be considered an ACTIVE DEVICE and since it's not listed in R58 as an approved ACTIVE DEVICE, it can't be used to control motors or servos via the MXP.
Unread 09-02-2015, 12:34
We would be using it for drive encoders.
Unread 09-02-2015, 12:43
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Given what I know about the Digital Sidecar, I don't think you'd be gaining anything unless you installed a cRIO on the robot as well. From what I remember, all the IO pins basically wend directly to the module on the cRIO.
If you need more than the 10 IO and can't get an expansion board, I'd recommend using a multiplexer .
Example: https://www.sparkfun.com/products/9056
Alternatively you can use an A2D as below for inputs over I2C. That might be the easier method.
http://www.adafruit.com/products/1083
Unread 10-08-2016, 18:31
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Would it if you don't power it? I was under the impression that the Digital Sidecar was just a breakout, and the power input was because cRIO cards needed to be powered individually.
Edit: Looking at the schematic, it seems that it is mostly a breakout aside from the relay and I2C slots.
