Go to Post there is no such thing as too many parts or useless parts, only parts you dont need yet. - Cuog [more]
Unread 11-08-2016, 19:54
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Non-FIRST Motor Suggestions?
Originally Posted by page2067 View Post
1st overall gear ratio - from CIMs to 8 inch wheels - recommend you find a link (search CD) for the JVN calculator - nice spreadsheet helps you get reasonable on what ratio will drive you and not overload.
I would seriously suggest using the JVN calc, it's really helpful and pretty easy to use. It will save you a lot of headaches, time and potentially a lot of money later.
https://www.chiefdelphi.com/media/papers/3188?langid=2
Sponsors, parents, students and mentors love helping teams succeed. Denso Throttle motors also want to help, don't break their hearts. REDBOX(gearbox for the throttle motor)
Facebook
Unread 21-08-2016, 19:19
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
One question about the JVN calc; the "Driving Gear" and "Driven Gear" fields take a custom value, but it's not clear what the number that goes into them is. I'm assuming it's asking for gear teeth, or is it something else? I'm guessing the driving gear is the one connected to the motor's output shaft, and the driven gear is the one driven by that gear?
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 21-08-2016, 19:26
pilleya's Avatar
Elec+Mech
Yes it is the number of gear-teeth, the same applies for the number of teeth on sprockets or belts. You can also just type in the reduction that you want say 1:3 etc.
Some gearboxes have more than one stage, but take it as the driving gear is before the reduction and the driven gear is after, so the driven gear should be rotating slower than the driving gear.
Yes the driving gear in a single stage gearboxes is the gear on the motor's output shaft
Here is an example of what it should look like for the reduction stages of a 10.71:1 Toughbox Mini or Micro(the stock ratio):
Facebook
