Go to Post Your best friends are all team members and you could never live without any of them because robotics people are the best people. - Riverdance [more]
Unread 11-08-2016, 20:11
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Re: pic: Its twins - prototype drives
Originally Posted by Jonny_Jee View Post
I'm a little late to the party here but according to MEADinfo.org
1 Spur 1:1 to 6:1 94-98% Efficient
2 Straight Bevel 3:2 to 5:1 93-97% Efficient
reference:
"Comparison of Gear Efficiencies." MEADinfo.org . N.p., n.d. Web. 11 Aug. 2016. <http://www.meadinfo.org/2008/11/gear-efficiency-spur-helical-bevel-worm.html>.
Are those figures assuming that exact center to center spacing is used? If so, spacing those gears out just a few thousandths can squeeze out some extra percentage points to make up for any loss. It's the first stage of gearing, so the loss in load capacity shouldn't be an issue.
Looking at that page, I realized the OP could probably switch to spiral bevel gears without much increase in price, depending on the supplier they're using, but since they already have the straight bevel gears they need, it probably doesn't matter.
