Go to Post Strive for excellence in everything you do, but also recognize it in others when you see it, rather than try to drag it down. - Joe G. [more]
Unread 16-08-2016, 20:01
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Using a Tesla M2090 for CAD
So I recently got my hands on a OLD Tesla m2090 gpu and was wondering if there would be benefit/anyway to run it at the same time as my GTX1060? This would be for Solidworks purposes.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 16-08-2016, 20:13
Knufire Knufire is offline
Re: Using a Tesla M2090 for CAD
Nah, don't bother. Not worth the hassle or power draw. That card was Fermi based, which is a design several (four?) iterations previous to your current card. Fermi was also the last design Nvidia pushed out before realizing that they needed to care about power efficiency, so those cards were power and heat monsters.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 16-08-2016, 20:19
Munchskull's Avatar
Team Role: CAD
What if power and heat were not and issue. Would it add quadro level 10-bit performance?"
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 16-08-2016, 20:32
What are you looking to accelerate specifically? Hunting down information on exactly what is GPU accelerated and the performance gains from going to a workstation card in Solidworks has been a PITA for me.
The most obvious difference for me having a "certified" (read: workstation) GPU was enabling RealView Graphics, which I found horribly annoying and turned off anyway.
Unread 16-08-2016, 20:56
Jared's Avatar
Jared Jared is offline
You won't get a benefit. The GTX 1060 is way more powerful than you would likely need for any FRC related CAD, but it's not a workstation card.
If I were you, unless I had a specific purpose for the M2090 I'd sell it and buy a quadro/firepro graphics card for SolidWorks. SolidWorks and most other CAD software uses OpenGL and video games almost always use DirectX. OpenGL stuff works way better on a workstation graphics card - you do a ton with even an entry level workstation card. SolidWorks is much more stable on a workstation card than a gaming card.
Something like an M2090 is really hard to take advantage of unless you really know what you're doing. MATLAB has pretty good support for doing lots of matrix operations with CUDA cores/xeon phi hardware, but something like SolidWorks can't really take advantage of the technology.
Unread 19-08-2016, 03:05
tragic tragic is offline
Programming Mentor
FRC #4633 (Bobcats)
tragic is an unknown quantity at this point
As others have stated your GTX 1060 will crush that Tesla in compute performance. I have a bunch of fermi series card lying around but I would never use them for anything except for diagnostic purposes. (testing to see if a different GPU is pooched.)
To really put this in perspective that Tesla has 512 CUDA cores while your GTX 1060 has 1280 CUDA cores. Not to mention increases in instructions per clock, much higher memory bandwidth (this huge to increasing performance as the GPU is often starved of data for large amounts of time), driver run time overhead reduction among other things all while using less than half the power and emitting less heat. Your 1060 is probably well over 5 times the performance of that Tesla.
Unread 19-08-2016, 03:43
TAlholm's Avatar
TAlholm TAlholm is offline
Mainely CAD
AKA: Tim Alholm
TAlholm is just really niceTAlholm is just really niceTAlholm is just really niceTAlholm is just really nice
It would be difficult to justify using the M2090. It is based on the Fermi architecture, which bears the nickname "Thermi." In Visualize or simulations, you MIGHT notice a performance increase, if even that. Then again, for FRC purposes, you will not need it.
FRC Team 1991 (2013 - 2016) - Head of Design / Head of Scouting
Don't trust me to cut down a straight line, unless it's on an automated router or mill.
