Re: Idea to Balance Championship Divisions
I think this has merit and should lead to more balanced divisions... it's reasonably straightforward to implement and doesn't rely on rank or statistics that are subject to change each year.
The one thing that I think FIRST would likely find as a significant sticking point is having the Chairman's and EI (Culture Awards) as the third sort instead of the first. I agree with you that having them third is probably more likely to result in well-balanced divisions from an on-field performance standpoint, but even if the Culture Awards were moved to the first-sort I think this general method would probably still be better than the status quo. |
I think they should do a draft... with previous championship WFA winners each picking divisions.
Could make a draft night show out of it. ![]() EDIT: And with the 10th round, 86th pick of the draft, Andy Baker selects 3940 for Newton. |
I think FIRST hasn't TRIED to balance championship divisions, other than making sure rookies are relatively evenly distributed. If they wanted to, they could do some sort of structure like you're suggesting, Brian, or literally just distribute teams evenly by OPR. It's not too difficult to create even divisions, they just haven't tried. |
I vaguely remember, perhaps a decade ago, teams were accused of gunning for particular awards and registering for particular regionals because they believed it would get them in a "favorable" CMP division. Does anybody else recall this?
The reason I bring this up is setting the precedent for teams being accused of colluding before the season to end up in the same CMP division, if they knew and could outsmart the placement algorithm. |
I guess I'll weigh in a bit.
Personally, I think the current way divisions are organised is just fine. Sure, this year we got extremely competitive divisions and some less competitive divisions, but that's just the nature of how these things work out. From what I understand the current (or at least, 2014, judging by the earlier link to FIRST's own website) system for sorting for championships is done in a sort of round-robin style, first with rookies, then with veterans. In this way, it's very hard to introduce bias into the division split. The same would be true for generating division placements by random number. In both ways, there's no 'filter' applied to each division, making it seem like a fair and balanced way to distribute teams. In the suggestion given by the OP, it seems like they're suggesting much the same system, but breaking it up to more categories than just "rookie/veteran", i.e. round-robin on pools of qualification level (winner, finalist, award, pre-qual, waitlist etc). This is all well and fine, in fact, from face value, it's better than the current system. However, don't stop reading here. The main problem with ALL methods of distributing teams is that teams aren't individual, but play in alliances. The performance of the whole alliance depends on how each team within that alliance performs, and how they perform together. This is the reason I don't think splitting teams in this way will make a huge difference when looking at the bigger picture, because rankings all come down to alliance allocations in matches. For the sake of argument, let's say it does make a difference, and the (objectively) best teams end up ranked after each other in descending order. During alliance selections is really where things start to kick off. At the end of the day, no matter the distribution, Alliance selections will often follow the same kind of recipe: "Top Team / Top Team #2 / Middle Team / Last Team". When it comes to playoffs within the divisions, only one alliance can be victorious. This gets rid of that team-stacking distribution we saw this year on some divisions. I believe that this is the reason playoffs and alliance selections are the way they are. Now would be a good time to mention that all of this comes down to interpretation. As a final point, playoff matches are where the real competition starts, and qualification matches depend almost entirely on how the alliances are made up on the match schedule. Through either distribution of teams, I theorize that the same teams would end up on Einstein either way, which is where the competition really amps up to another level. Again, this is all just my interpretation of each distribution and how I *THINK* it would work out. Don't take it as gospel |
Here is a question. Do stacked divisions actually matter?
Most people would agree that the threshold of "stacked divisions mattering" would be that they usually win champs because they are "stacked". Lets look at the data. (Taken from this post on average OPR) Code:
Year Winner Prechamps OPR rank 2016 Carver 4 out of 8 2015 Newton 4 out of 8 2014 Curie 4 out of 4 2013 Galileo 1 out of 4 2012 Galileo 4 out of 4 2011 Galileo 2 out of 4 2010 Newton 4 out of 4 2009 Galileo 3 out of 4 2008 Galileo 4 out of 4 2007 Newton 1 out of 4 2006 Archimedies 4 out of 4 2005 Newton 4 out of 4 2004 Archimedies 1 out of 4 Scaled avg for 8 divisions is an average pre champs OPR rank of 5.54. So... No correlation. What about how well "Stacked" divisions preformed at champs? (Based on avg opr) Code:
Year Division Result 2016 Newton QF 2015 Carson QF 2014 Archimedes QF 2013 Galileo W 2012 Archimedes QF 2011 Curie F 2010 Archimedes QF 2009 Newton QF 2008 Archimedes QF 2007 Newton W 2006 Newton F 2005 Archimedes QF 2004 Archimedes W If someone wants to do avg of the top 24 for each division so we can redo our analysis, but right now your odds don't look particularly good for this whole "division" balancing having any impact. Looks like divisions don't really need to balanced from everything I can see. luck in match schedule and creating a cohesive and competent alliance matters way more. EDIT In fact the top 5 most "stacked" divisions 4/5 got KOed in the first round on Einstein. That makes sense. 50% of teams get KOed first round, hence it's at best a random correlation, and too small of a sample size to actually say that the majority of stacked divisions actually perform poorly compared to average divisions. Code:
1 2016 new QF 2 2015 cars QF 3 2005 arc QF 4 2008 arc QF 5 2013 gal W Last edited by BrennanB : 17-08-2016 at 13:58. |
#7
I don't think "most people" would say that, and the OP definitely didn't. He said "improve the Championship experience for everyone", not just the few teams that make Einstein. Many teams want to play with the best in the world, not watch them compete in another division.
#8
#9
As Jaci mentioned, since (bar bad scouting) you only have two "top" robots per alliance, stacked divisions don't end up with a stacked alliance on Einstein. Stacked Einstein alliances are almost entirely due to bad scouting by the majority of the division they come from. What they do result in is many stacked alliances in divisional playoffs. Some of those alliances that lose in the semis or finals of a stacked division could be objectively better than alliances that win weaker divisions, and it sucks for those teams to know that they missed out on Einstein just by being unlucky in their assigned division.
What's the opportunity cost for making this change? I've seen some people debating that it would make a positive change, and some arguing that there wouldn't be a significant effect at all. Does anybody thing this would cause a negative change? |
#10
I propose that they just go back to what they used previously.
Let the divisions be letters A, B, C, D, E, and F. Let the teams that register be 1, 2, 3, ..., n, sorting by numerical order. 1 goes in A, 2 goes in B, 3 goes in C...6 goes in F, 7 goes in A, 8 goes in B...n goes in the next-in-sequence of A-F. Assign A-F to random division names. The problem (or not) with this method is that anybody can generate a division list with a few minutes and some programming knowledge, and knowing which teams are signed up. |
#11
I too like the segmenting approach to assigning. It's really only a variation on what FIRST is already doing. |
#13
The implication of your post, Brennan, is that the primary downside of a stacked division is an unfair advantage on Einstein. I don't think that's the main reason at all that unbalanced divisions are a bad thing. It's mainly the worse playing experience playing in an overly strong or weak division, good teams being cut from the elims because they lucked into the strongest division, etc.
Anyways, we have all of this information - anyone invested in this idea could do some programming and spit out 8 hypothetical divisions this year sorted by this algorithm, and then analyze these divisions using different metrics (OPR, etc) to see how unbalanced they are. I'd love to see this sort of analysis. |
#14
The pools are: Code:
Winner AC/1 Wildcard AC/1 District Points CA/EI RAS Prequalified Waitlist Winner 2/B & Wildcard 2/B I've attached an OPR chart for the different divisions, along with the actual distribution last year. The balanced distribution looks slightly better, but there is still a division that's clearly above everyone else. Last edited by AGPapa : 19-08-2016 at 13:37. |
#15
