Re: Proposal for Wildcard Reform
Similarly, at the 2016 Finger Lakes Regional, the #1 seed was upset in the semifinals, despite having the two best scoring robots at the event, and 2791 yet again did not get a bid to championships. Now I'm using the example of 2791, because I know them well, and they're a team that this regularly happens to. 2791 has missed championships by the tightest of margins at two regionals in 2012, one in 2013, and two in 2016, while also fielding a tremendously competitive robot in 2014. Essentially this would come into play whenever a regional would generate enough wild cards to bring along the finalist alliance's third robot, or whenever a wild card slot is wasted, it could instead just go to the next team with the most points. |
Including here as it's relevant... Here's the breakdown of wildcard slots at each regional from 2016 (excl Ontario):
https://drive.google.com/open?id=10P...hkP4sZFtrV zg |
Certainly that's part of it. But wildcards were around before we were in a district. Also, there aren't any nearby original or sustaining teams or hall of fame teams.
Some sort of further wildcard distribution could be very useful in Minnesota. In 2016, both of the events 2823 attended had 2+ wildcards. Lake Superior had 2 (thanks 359!), and 10k had 3 (and possibly could have had 4 if they had awarded rookie all star). We were very fortunate to qualify off of the waitlist to champs after losing in semis (to 2052) at both regionals. Had we not been so fortunate, we would not have gotten to see our robot run at peak performance, win 10 qualification rounds, and have an amazing trip. With the extra wildcards added already, there will might be less impact in Minnesota than other regionals without some sort of further distribution rules.
That said, District Points may be unnecessarily complicated for this. I can't think of a simpler way, but it might exist. |
#7
I've updated the Google Drive Spreadsheet earlier in the thread to include a calculation of district event points for the Sacramento event.
I picked Sacramento as it's mid-season, and all 3 members of the finalist alliance already had bids to CMP. Two caveats:
On a point basis... some interesting things:
All in all I'm surprised the alliance captains didn't get more of a boost, and that award points played a significant result. Without them 701 and 3250 would not be anywhere close to in the running for a wildcard slot. I'm interested to see what the rookie / 2nd year points boosts do. If someone wants to know, either post here, or PM me the team # ranges for rookies and 2nd year teams for 2016. I'm just too tired to go looking right now. ![]() |
#8
Only 4 events generated burned WCs under the '16 rules, not surprisingly mostly later events. There were, however, two events that generated 4 wildcards, and at Lone Star two of those were burned. All in all under the '16 rules, we used 57 WCs and burned 5. Under the '17 rules (thus far) we would have used 88 wildcards and burned at least* 22. (* - If a team would have gotten a WC under the 2017 rules in an earlier event that is not reflected in the burned total. Thus, this is a minimum number without going through and recalculating WC generation regional-by-regional for the 2017 rules. The spreadsheet calculates the 2017 WC generation as a simple +1.) What's clear is that the 2016 rules did not have a material effect on the number of teams that "lost" out due to burned wildcards (92% of WCs used), but if we used the 2017 rules that would change with only about 80% of WCs being used. Put another way, ~41% of the newly generated WC slots would be burned under the 2017 rules as they are. |
#9
Combine that with the wild card slots, and you'll at least have something to look at. The only thing it doesn't give you is the points for a team's second event, which may throw things off a little. Quote:
#10
-George |
#11
It's somewhat more relivant under the proposal here because this would ensure a distribution of all wildcards under the points model and not artificially cap the number of potential wildcard recipients at three. If the rest of your argument truly reflects FIRST's intentions, they want more representation, but not that much more, than they could tweak the proposal here to cap at x wildcards per regional. |
