Go to Post A 823543:1 reduction should be fine if you ever need to pick up a truck...or a house. - Tim Sharp [more]
Unread 19-08-2016, 10:21
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Re: Found out why the pivot on our 2014 arm wasn't working
Originally Posted by cbale2000 View Post
How on earth did you get that stage to fail in 4 different spots at the same time? And all across the pin holes. Almost looks like someone cut it into 4 even pieces.
Seeing this makes me like the VersaPlanetaries even more. Their manufacturing tolerances and material consistency must be very good for all four pin holes to fail at about the same time. This is assuming that the OP exceeded the torque ratings on the gearbox. I'd love to hear how this happened.
Unread 19-08-2016, 10:25
AdamHeard's Avatar
Lead Mentor
It's more likely that one failed, then the rest did in order.
Unread 19-08-2016, 11:13
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
If one had failed before the others wouldn't you expect to see differences in the breaks or other damage elsewhere in the gearbox?
