Go to Post Just because something has never been done, doesn't mean it's impossible. See: everything ever. - Taylor [more]
Unread 19-08-2016, 14:09
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
Re: Found out why the pivot on our 2014 arm wasn't working
Originally Posted by s_forbes View Post
Neat! I like when things break, it's educational!
Looks like a 5:1 versaplanetary stage. What motor was driving it, where was this stage in the transmission, and what did the mechanism look like?
It was a 2-stage VP driven by a CIM (pre-CIM Converter). This then drove the sprocket in the middle of the picture through a chain reduction which then rotated the whole arm. We had many failures during the season with this gearbox, and in this case the output stage failed.
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 21-08-2016, 00:25
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Do you know what the reduction was for the other stage by chance?
Vexpro has a fantastic user guide for their versaplanetary gearboxes that shows what load rating you should expect the gearboxes to withstand. I bring it up every year when we're designing to show the students that there is a limit to what the gearboxes can do. It's an excellent example of "here's what the supplier says their product can handle. We have to stay in that range or it might break".
I also try to make sure that our versaplanetary assemblies have the highest reduction stages near the motor, and not the output shaft. The lower reduction stages have more meshing gears and should be able to handle higher torques, so they are the ones you want at the output of the gearbox.
By the way, I have to mention that with the beautiful carbon fiber tube and aluminum clamp construction that your team uses every year, I'm not surprised that the gearbox was the weak point. The construction of your mechanisms looks really solid!
Unread 21-08-2016, 10:01
jnicho15's Avatar
AKA: Dan
Looks can be deceiving...
Unread 21-08-2016, 12:38
Best Available Data
FRC #1778 (Chill Out!)
For us, this always ends up as: "Here's what the supplier has rated their product for. We've had some requirement creep, so we're going to assume they did their homework and eat into their safety factor."
