Go to Post No FIRST event is complete without Darude's Sandstorm. - sonichammer7476 [more]
  #76   Spotlight this post!
Unread 20-08-2016, 00:29
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Re: Chain vs. Belts?!?
Originally Posted by C.Lesco View Post
Chains suck if you dont know how to instal them or get that finicky half link in however used correctly i think its fine. As for belts, a good belt is better in my opinion "but belts might stretch" people argue. Youre using the thing for 6 hours flat out total at most, it doesnt matter in the time span of build and comp unless youre using a multiyear old belt. BELLLTSSSS
For FRC applications belts shouldn't stretch. Chains will stretch though.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
  #77   Spotlight this post!
Unread 20-08-2016, 01:17
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
I've heard that multiple times, but I've always wondered what "FRC applications" means. After all, one team's robot might go through tons of matches and hours of practices. Another team's robot might go through just one competition with minimal practice time. Doesn't the difference in runtime affect how much chains/belts stretch?
  #78   Spotlight this post!
Unread 20-08-2016, 01:26
Division by Pirates
For chains definitely. Belts just don't really stretch under normal loads of an FRC robot.
  #79   Spotlight this post!
Unread 20-08-2016, 01:51
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Because of the fiberglass tensile members in the belts we use, there isn't much 'stretch' in the belt at all, regardless of loading. Basically, if you're putting enough load on the belt to stretch it, it's about to snap, and cause a complete failure. Belts do not stretch appreciably over time. Theoretically, the teeth of the belt will deflect under shock loading because the tensile members do not support the teeth themselves, but that doesn't really affect wear and tear, that just increases the likelihood of ratcheting when you're overloading the belt's hold on the pulley.
  #80   Spotlight this post!
Unread 20-08-2016, 17:50
Oblarg Oblarg is offline
AKA: Eli Barnett
Yes, but even given the variation in runtime between different FRC robots, the runtimes of all FRC robots are on a scale that's orders-of-magnitude smaller than that of these parts in actual industry, so "FRC applications" remains a very meaningful distinction.
"The breakfast of champions!"
  #81   Spotlight this post!
Unread 20-08-2016, 18:09
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
How does one account for stretch? Tensioners like delrin rods on bolts?
  #82   Spotlight this post!
Unread 20-08-2016, 18:13
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Basically having tensioners at some point, yes. There's a lot of ways to do it, including using idler sprockets, bare tensioners like you describe, or moving the bearing blocks farther away from each other via a Vex cam.
I heard from someone on 1296 that they used preloaded chain to account for chain wear-in so that they could run direct C-C without any change in tension over the course of a season.
  #83   Spotlight this post!
Unread 20-08-2016, 19:22
Division by Pirates
All sorts of different ways to tension chain. You can find nice ones on McMaster but are expensive, but if you don't over tension you can get away with Delrin of some sort.
Be careful to not over tension. Cost 229 a chance at a regional win this year.
