Go to Post FIRST isn't a competition. It's a learning experience. Share the knowledge, and you'll learn more because there's bound to be someone who sees something about your project that even your own team didn't realize it can do. - CalTran [more]
Unread 22-08-2016, 09:00
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
pic: Modular Gearbox
Unread 22-08-2016, 09:03
Chris is me's Avatar
AKA: Pinecone
Re: pic: Modular Gearbox
While this is a cool design and all and I don't mean to discourage you, it certainly has been done before. One of AndyMark's early products was the StackerBox (now discontinued?), which did essentially the same thing as this. One could also argue that this is basically what a VersaPlanetary is, minus the planetary part of course.
I would switch the bearing holes to 1.125". You can get both 3/8 and 1/2" hex in that size, so you can pick what size shaft to use based on the stage of the gearbox.
Unread 22-08-2016, 10:33
Ari423's Avatar
FRC #5987 (Galaxia)
I can't find the StackerBox on AndyMark's website, but from what I can tell they seem like similar ideas (great minds think alike!). Any idea why the Stackbox wasn't successful and was discontinued? My idea was to have something similar to a VersaPlanetary in its versatility except a spur gearbox not planetary, so it can be used in higher torque situations like a drivetrain or a heavy arm. Also spur gearboxes allow you to make smaller changes in gear reducation than planetaries, which can be useful to maximize the mechanism's efficiency.
The bearing holes, aka the two in the center where the axles go in the example, are 1.125" for exactly that reason (well 1.123" for a tight fit but yeah). All of the 3/4" holes are just lightening holes because the full aluminum tube was unnecessarily heavy IMO. I suppose you could put a bearing in them for some reason or other, but that's not their intended purpose. The only holes that are intended to have bearings in them are the two 1.125" holes in the center (or the four 1.125" holes in the double block).
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 22-08-2016, 11:12
AKA: Pinecone
I just misjudged the scale of the render and thought the bearing holes were 7/8, my bad.
I can only speculate on what happened with the StackerBox (I never bought one), but I suspect the main problem was that it had limited use cases. If you wanted 2 stages, you'd just get a ToughBox; if you wanted more than that, you could get an AM or GEM Planetary. There was also less variety in gear sizes then so it doesn't have as many possible ratios as the 84T Vex spacing allows.
Any way you could move to maybe 3/4" wide tube instead of 1" tube? At the moment its not very compact, and this would thin things out a bit.
Unread 22-08-2016, 11:18
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
It seems to me that a system like this requires more space and weight than a gearbox that's just designed to have X number of stages to begin with. Something like this could be great for prototyping - you have a bunch of stages sitting on a shelf and start putting them together until you find the ratio that works best - but that's as far as I would use it. Once you know what your application needs, buy a gearbox with that ratio. The weight savings can always help, and the space savings may be a significant difference in some robot designs.
2016: Lake Superior WFFA
Unread 22-08-2016, 13:33
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
To echo what has already been said, I think the main issue is that all they were good for is prototyping; for actual competition use they're a solution in search of a problem.
Unread 22-08-2016, 14:00
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
It came out right before the explosion of new AI hex bore gears happened. This made custom gearboxes much easier to make. The the VP came out.
It was a great possible solution that just arrived a little too late.
Unread 23-08-2016, 04:44
Ari423's Avatar
FRC #5987 (Galaxia)
The tubes there are actually 1.5" wide. Inside each tube needs to fit one gear (.5"), one shaft collar (.25"), and two bearing flanges (.0625" ea). 1" tube with a .100" wall gives .8" of inside width, which is .075" too small to fit everything. I was able to reduce the outside tube width to 1.125". I could further reduce it by removing the shaft collar and replacing it with two retaining rings, but that would require the shafts to be machines which I didn't want to do.
You can see the updated model at the same grabcad link.
2013: Programmer
Unread 23-08-2016, 07:34
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I agree that you would not want retaining rings, even if machining were not an issue - they're a high-stress point.
Did you consider using thunder hex stock? Not because it's rounded, but because it has a bore. You could retain the shafts with self-tapping screws and washers (or tap the hole and use elevator bolts) and save a few tenths relative to shaft collars. There may be other pre-bored hex stock out there as well. Churros would work for demonstration purposes, but are not good for transferring the torque you'll need in a drive train, much less an arm.
Unread 23-08-2016, 08:36
Ari423's Avatar
FRC #5987 (Galaxia)
I thought of that, but I don't think it would work. Right now, the flanges are on the inside of the tube and the shaft collars are inside of them keeping the bearings from falling inwards. The screws on the end of the shaft would only be able to be outside of the bearings, meaning the bearings would have to be flipped so the flanges are on the outside of the tube. Because of that, the rest of the bearing is sticking through the tube wall .15" into the tube, taking up more space than the shaft collar.
*Let me know if I'm not explaining that clearly*
2013: Programmer
Unread 23-08-2016, 12:51
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
If you remove the collars from the inside you could replace them with a spacer so that the bearings (with their flanges on the inside) are flush against spacer or gear. Make the spacer long enough so that it presses against the gear and the gear presses against the other bearing. Doing that, you would only need a bolt/washer combo to retain the shaft axially if it isn't already held stationary by something else.
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
Unread 23-08-2016, 13:34
Sure, it's a stress point... but is it really that big of a deal? We've used some AndyMark Toughbox Nano's in several applications (including drive train) without any issues at all, and they use retaining rings. In fact, we have one pair of Nano's that's made it through two seasons on two separate robots, with a season in between where it was used for practice. That experience would seem to indicate that using retaining rings may not actually be all that bad.
Unread 23-08-2016, 14:03
AKA: Pinecone
It is a big deal if the snap rings are placed between loads on a shaft. They are a major stress riser then. They are fine on the ends of a shaft, but I would never (again) put them between torques, especially on higher reductions.
In this application - can you just have bearing / gear / bearing on the inside of the tube, and shaft retention handled elsewhere? That would require an inner width of only .75, which lets you use 1" wide .125 wall tubing.
Unread 24-08-2016, 05:54
Ari423's Avatar
FRC #5987 (Galaxia)
That's a really good idea that I hadn't considered. With your suggestion, I was able to reduce single block to 1" wide, .125" wall and the double block to .75" wide, .100" wall. The 1 CIM gearbox is now 2 lbs and the 2 CIM gearbox is now 4 lbs (without motors). That makes the whole 2 CIM gearbox 2.75" wide.
Updated CAD models are at https://workbench.grabcad.com/workbe...ulyGgP-1FFgvMU
The other big problem I can't figure out how to avoid is that the CIM motor needs a trimmed shaft and a spacer (could be CIMcoder) to fit in the thin stage. I was really trying to not need any machining after the blocks are CNC'ed. Does anyone have any ideas how to get around this problem?
2013: Programmer
Unread 24-08-2016, 09:25
AKA: Pinecone
One more thing I want to remind you (and sorry to dominate the posts of this thread!) is that you want to make sure all of the tubing sizes you're using are readily commercially available. For example, .100 wall tubing is very uncommon outside of what Vex sells; most of it is 1/8" wall and 1/16" wall. Also, some of the odder sizes are only available in 6063 tubing, which, albeit weaker and crummier to machine, it is adequate for this application in 1/8" wall if there isn't a 6061 alternative.
