Go to Post IRI seeks to invite the very best robots to play the FIRST game, achieving the highest level of play, while keeping in place the FIRST atmosphere. - Nathan Streeter [more]
Unread 23-08-2016, 15:02
AdamHeard's Avatar
Lead Mentor
Re: CAN to PWM converter?
Originally Posted by asid61 View Post
Forgive me, but I don't know enough about CAN to see where $20 to $30 came from. I was looking up general-purpose CAN controllers and microcontrollers and found options in the $1-3 range, and PCBs should only cost $1-2 tops. What would drive up the cost?
That's pretty fair. But if you could do it for cheap or wanted to try out CAN in general, a cheap converter would be useful. Plus, it would be easy to go from converter to SRX without changing much code.
Not all of the profit in the per item reference frame goes to the overall business profit... Most of it is eaten up by salaries of engineers, warehouse, quality control, support etc...
I know nothing about the COTS FRC Market, but I wouldn't be surprised if the per item cost on a Talon SRX is in the $20-40 range.They need to sell it at $90 to cover all the overhead and still make a profit.
Unread 23-08-2016, 16:11
Joining the 900 Meme Team
FRC #0079
PCB fabrication is cheap, populating it? Less so. Add in a case, quality control, development costs... I've got a hunch COTS would be in that range if not a little higher.
Unread 24-08-2016, 08:56
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Not to mention programing & design time. If you are doing it as a hobby or have students do as a project that might not be much of an issue. If you have to actually pay your programmers and engineers, it starts to add up. Quite expensive for a prototype or small production run. Obviously the per unit costs come down with the more you make.
