Go to Post Ask the right questions and you can get the right answers. - Chief Hedgehog [more]
Unread 23-08-2016, 18:22
tkdberger's Avatar
tkdberger tkdberger is offline
SPAAACE
AKA: Hugh Mungous
FRC #3494 (Quadrangles)
Rookie Year: 2016
tkdberger is an unknown quantity at this point
Unhappy Having trouble deploying code
Hi!
Our team is doing a demonstration of our robot very soon and we need to deploy code onto it. I'm essentially working on a new computer, and just got the FRC plugins and NI software from the 2016 competition loaded onto it. I'm using Eclipse Mars, because Neon wouldn't install the FRC plugins. Our source code can be found at https://github.com/tkdberger/3494_2016_repo.
However, whenever I try to deploy code, over any method, it will build fine, but the actual deploy process does nothing. I'm left staring at a blank console window labeled with
<terminated> build.xml [Ant Build]
and then the path to the JRE, C:\Program Files\Java\jre1.8.0_101\bin\javaw.exe
Other notes: Eclipse consistently gives the following error on start:
An internal error occurred during: "Initializing Java Tooling".
    org.eclipse.core.runtime.SubMonitor.split(I)Lorg/eclipse/core/runtime/SubMonitor;
Please help, we really need a driving robot ASAP
Unread 23-08-2016, 18:44
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant future
Re: Having trouble deploying code
There's a number of settings to check in eclipse. I don't have our team laptop to check what all they are. Did you make sure to go through the WPI lib steps: https://wpilib.screenstepslive.com/s...ller-java-only
I seem to remember something like checking boxes for wpilib and networktables after right clicking on the project -> properties -> Java Build path.
There's also checking to make sure that you have the team number set up correctly in your project and when you set up your rio.
I'm assuming you have the same language on the rio now as you did last time you used it as well.
Really need more information from the output console to help.
Some notes from the last time I tried to help someone remotely trouble shoot why code wasn't loading. I also just noticed this is the C/C++ forum and not java, but I imagine there are similar things to look for in eclipse.
Ensure that you roboRIO is imaged correctly. If you connect up a laptop to the rio and go to roboRIO-3494-FRC.local you should be able to connect to the rio. If you can't, try using a USB cable and going to 172.22.11.2. If that doesn't work - I'd make sure you completed these steps properly:
http://wpilib.screenstepslive.com/s/...borio-firmware
http://wpilib.screenstepslive.com/s/...g-your-roborio
http://wpilib.screenstepslive.com/s/...ller-java-only
Open up eclipse and go to Window -> Preferences then go to Java -> Installed JREs. Make sure that under the name/location it says JDK and NOT JRE. If it does not have JDK, delete the current one, add a new standard VM. Go to C:\Program Files\Java\JDK1.XXX (it may be Program Files or Program Files (x86)
If that's correct then in the preferences window still go to WPILib Preferences and make sure your team number is there
If that's correct then right click on your project, select Properties, then go to the Java BUild Path and make sure that the wpilib, networktables, and jdk system library are all checked
If that's correct then I would do File -> New -> Project. Then select WPILib Robot java Development -> Example Robot Java Project then select the getting started sample project and just try to load that. If that works then for some reason something in your code is preventing it from loading.
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 23-08-2016, 18:54
tkdberger's Avatar
SPAAACE
AKA: Hugh Mungous
Rookie Year: 2016
I've been through all the documented steps. I thought the one you linked was irrelevant as our code is in c++, but I may as well do it anyway.
I just ensured the team number is correct, I'll get back to you with results.
The main issue is that the console isn't printing out anything, at all. I can film this if you want.
Unread 23-08-2016, 19:06
ahartnet's Avatar
Sorry, I noted that this was the C/C++ forum without me updating my link. The correct link to make sure you go through is here: https://wpilib.screenstepslive.com/s/4485/m/13810. In particular, look at the addendum if you're running windows 8
Unread 23-08-2016, 19:12
tkdberger's Avatar
SPAAACE
AKA: Hugh Mungous
Rookie Year: 2016
Currently re-installing Eclipse. Will get back to you.
Note to self: do not allow laptops to be re-imaged unless steps are documented to restore them.
Unread 23-08-2016, 19:44
tkdberger's Avatar
SPAAACE
AKA: Hugh Mungous
Rookie Year: 2016
I'm on the verge of madness here.
I've reinstalled Eclipse at least three times now. Every time it manages to remember the broken config from the last one. Each time, the 'Install new software' option appears on the help menu exactly once before vanishing.
The option for running as a deploy is gone. I can't get it to come back.
I fell like I'm living in a nightmare right now. I hope I am at this rate.
Unread 23-08-2016, 20:00
ahartnet's Avatar
After you've installed eclipse (and perhaps again after you've installed the frc plug-ins) try restarting the computer.
I've never seen the 'install new software' disappear before.
Unread 23-08-2016, 20:07
tkdberger's Avatar
SPAAACE
AKA: Hugh Mungous
Rookie Year: 2016
It may have to do with the way the compute is connected to the internet. I'll experiment when/if I can
UPDATE: Found the reason for the configs being unchanging, I think. In the home folder there's a .eclipse folder that likely contains all configs.
Last edited by tkdberger : 23-08-2016 at 20:32. Reason: add why config was constant
Unread 24-08-2016, 13:06
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Try running build.xml manually. Install ant, then in your project directory open a terminal and run
ant deploy
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 24-08-2016, 13:22
tkdberger's Avatar
SPAAACE
AKA: Hugh Mungous
Rookie Year: 2016
Question Re: Having trouble deploying code
ant deploy
I'll try that, thanks
Unread 30-08-2016, 10:20
tkdberger's Avatar
SPAAACE
AKA: Hugh Mungous
Rookie Year: 2016
Smile Re: Having trouble deploying code
Update:
.eclipse is indeed the culprit of the "Install New Software" button vanishing, that and the fact that the computers at school have a proxy on them (for "security" reasons).
Unread 30-08-2016, 13:45
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Originally Posted by tkdberger View Post
Update:
Ahh, the classic school "security" that never seems to be done right, at any school.
Unread 30-08-2016, 19:09
tkdberger's Avatar
SPAAACE
AKA: Hugh Mungous
Rookie Year: 2016
True that. At least our robot drives now, since we have a DS and a RoboRIO with code deployed from competition.
Unread 01-09-2016, 20:11
tkdberger's Avatar
SPAAACE
AKA: Hugh Mungous
Rookie Year: 2016
Well, I'm not sure what i did, but working from a clean PC everything seems fine.
I am cautiously optimistic.
