Go to Post I have always gotten the answers I need. They're just not always the answers I want... - Alan Anderson [more]
  #31   Spotlight this post!
Unread 23-08-2016, 22:29
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: How are teams mounting drivetrain encoders on WCD?
I don't have any pictures unfortunately, but a couple of 1712s students designed a novel mount for the Versa block system. They 3D printed a piece that interfaced with the contour of the Versa block above the 2x1 channel (including the existing mounting holes) and stick out just beyond the end of our drive axle. There was an adjustable encoder mount that was then slid into that overhung lever, allowing a structural element to hold the encoder that could also slide with the Versa block as the block moved to tension chain.
  #32   Spotlight this post!
Unread 24-08-2016, 15:25
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
Would be cool to get a picture of this. Sounds like a cool add-on.
  #33   Spotlight this post!
Unread 24-08-2016, 15:40
AdamHeard's Avatar
Lead Mentor
Originally Posted by gc_coxen View Post
My mistake, I meant to say between mounting to the drive axle or a separate wheel axle.
FWIW, 254 generally (or always?) mounts their encoder on a wheel shaft and has some of the fanciest autos out there.
  #34   Spotlight this post!
Unread 24-08-2016, 17:22
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Just to make sure people understand here: Adam's example is valid proof that putting an encoder on an outer wheel axle will not inherently add too much variability to produce reliable autos.
I feel that it's worth adding that this is possible because 254 properly tensions their chains, which means the backlash/slop between the outer wheels and directly driven wheels is minimal. If you're using WCP sliding versablocks, you should be able to tension your chain/belt well enough to make this a viable solution as well.
As an aside, 254 and 971 gave a great talk at Champs 2015 which is recorded on Youtube about Motion Profiling and Control which is super helpful to understand how they get such reliable auto control. Worth looking at.
TLDR; If you have a reasonable tensioning method for your chains (esp sliding bearing blocks) you should be fine putting an encoder on one of the outer wheel axles.
  #35   Spotlight this post!
Unread 24-08-2016, 17:30
AdamHeard's Avatar
Lead Mentor
I don't believe 254 ran tensioners in 2016 or 2015.
  #36   Spotlight this post!
Unread 24-08-2016, 17:34
Volunteer, WPILib Contributor
no team (Waiting for 2021)
I think think another trick is making sure you put the encoder on the weighted wheels. That way you don't have to worry about chain tension, and the encoder should always be touching the ground, at least in most cases. Another thing some teams do is preload their chains. Instead of pushing your robot forward into its starting position, push it too far forward, and then pull back. This will preload the chains to they are tensioned in the right direction for moving forward, which helps reduce shock loads.
Team 4488 - Mentor 2013-2016
  #37   Spotlight this post!
Unread 24-08-2016, 19:10
Oblarg Oblarg is offline
AKA: Eli Barnett
This is an exceedingly smart idea that I think we will have to steal next time we do a DS drive.
"The breakfast of champions!"
  #38   Spotlight this post!
Unread 26-08-2016, 14:58
Nuttyman54's Avatar
Mentor, Tactician
Correct. I actually had a much longer post drafted up and then deleted most of it to keep it shorter and more straightforward. Tension your chains and you shouldn't have a problem.
I would consider a well-designed exact C-C setup to be "properly tensioned", such as 254 ran in 2015 and 2016 and 118 for the past few years as well.
Some quick math also shows that a few degrees of "slop" of the wheels relative to eachother will only result in a positional error of fractions of an inch (1 degree of slop on a 4" diameter wheel is less than 0.040" linear). While you may get some "noise" in your encoder values, you should be able to tune a PID loop to be stable with that amount of error and still give extremely precise auton navigation.
  #39   Spotlight this post!
Unread 26-08-2016, 15:03
Chris is me's Avatar
AKA: Pinecone
Isn't this backwards? If the robot last moved backwards, when forward voltage is applied it will have to drive through all of the slop in the system before moving forward. If the robot last moved forward, the slop is "behind" the applied power to the system, and it won't jerk as much. So you want the last "push" of a robot being set up for auton to be forward.
It's a good idea to push the robot back and forth a few times as you set it up, in either case, to make sure everything is running smooth and your drivetrain isn't stuck on a burr or anything like that. I've just always made sure the last push was in the direction the robot intends to travel.
  #40   Spotlight this post!
Unread 26-08-2016, 15:34
Its definitely pull if you want to go forward. If your motor is to the left of the wheel, when the motor attempts to drive the wheel, it will pull the bottom length of the chain tight. Pulling the wheel backwards also causes the bottom part of the chain to go tight, which is what you need.
  #41   Spotlight this post!
Unread 26-08-2016, 15:43
AdamHeard's Avatar
Lead Mentor
You're thinking in the wrong reference frame, forward in the motor frame is reverse when externally pushed.
  #42   Spotlight this post!
Unread 26-08-2016, 15:58
AKA: Pinecone
Well, I've been very meticulously setting up robots for auton wrong for like three seasons now. Thanks for the clarification.
  #43   Spotlight this post!
Unread 26-08-2016, 17:10
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Hate to ask such a stupid question (my team has never used chain. Only belts and even then only for the DT), but here goes.
A) What do you mean by the "weighted" wheel? Do you mean the dropped wheels?
B) What do you mean by preloading chain? How would this help? You said something about moving the robot forward and then back, but I don't understand how this would help.
Thanks so much!
  #44   Spotlight this post!
Unread 26-08-2016, 18:22
Thanks so much!
The weighted wheel would be the wheel with the most weight on it that is not the dropped wheel. For the setup being discussed, you couldn't easily put an encoder on the center dropped shaft. So the encoder would be mounted to one of the outer wheels. It the encoder is mounted to the wheel that is on the heavier side of the robot, that wheel will usually be in contact with the ground, and therefore the encoder is directly driven instead of through chain or belt. Its not a big difference, but sometimes the little differences help.
As for preloading, if your chains are not preloaded, as you start to drive the motors, there will be a split second where the motors will accelerate, but the wheels will stay stationary. This is because there is some slop in the gears and the chain or belt. This will then jolt the wheels when everything in the geartrain gets loaded, which can cause control issues if you want to be precise. If you preload the geartrain, which you do by moving the robot manually in the opposite direction you want to move, this jolt goes away, which allows much more controlled starts and more controlled acceleration.
  #45   Spotlight this post!
Unread 26-08-2016, 18:24
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Thanks so much!
I'd assume this would mean stretching out the chain before actually putting it on finally, so that it stretches less during actual use.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
