#226
Re: Video Review Needs to Happen Now
I think the point trying to be made is video replay may not be inspiring, on it's own, but it's a tool to prevent the kids from getting discouraged by bad calls. Thus it's a net positive to inspiration overall.
#227
I definitly agree with you both. My question is whether this (however amount) increase in inspiration is worth the longer waits, and possible teams leaving to prior awards, which, in my mind, decreases inspiration to those members (trying to quantify an unquantifiable thing ). |
#228
The argument saying time would be wasted is a bad one because it can be done so quickly that very little time is wasted. |
#229
tl;dr.
I am a full supporter of video review. If matches/events take longer as a result, then let it go longer. I can see where subjective calls not being reviewed is fine. But for missed calls such as breaching defenses in 2016, definitely could have used some video review. I cant see anyone arguing or being upset, if a call was overturned to get it right, where an alliance ends up losing a match instead of winning. Getting a right call trumps that. |
#230
Fair enough. All I'm saying is that benefits/costs should be weighed carefully. If it takes up little extra time and allows better calls, I'm all for it.
#231
This is basically a thought exercise, but if you ignore team sizes for a moment, which is more de-inspirational, potentially ending your season on a bad call, or having to leave the event that's run late a few minutes early? Another thought here is that wouldn't Gracious Professionalism suggest that a short delay, if needed, to get the call correct, be the right thing to do? |
#232
Encourage or discourage FIRST to change the rules from one season to the next, but once they are established, follow them. Last edited by gblake : 24-08-2016 at 19:03. |
#233
Can you elaborate on what happened? What was the call on the field/what was the challenge?
#234
For that reason, still color me undecided. YMMV. Blake Last edited by gblake : 24-08-2016 at 19:07. |
#236
I like the concept of video reviews being used to make sure the correct call is made, using technology to make the competition better seems like a very FIRSTish thing to do. We have loads of regionals, maybe FIRST could do a trial run at a few and see how it turns out?
One potential downside is that there might be more people in the front rows waving their iPads in the air. If that's a sacrifice we'd have to make, then I don't wanna do it. |
#237
Honestly, if I was to do a replay--and this is what I'd be pitching to offseason events--I'd figure out where the most non-judgement calls* were going to be. For 2016, that's the Defenses (and possibly the Secret Passage). It'll vary by year. That's where any cameras get pointed, probably one per area. If whatever is being contested is in view, then it's review time. If not, you're right out of luck, better luck next time. One other element that I'd be considering would be a case of "what if something else got missed?" My opinion would be that whatever gets caught on video but missed by the refs should be taken into account when determining if the outcome of the match was affected--and unless the outcome is ruled to be affected, the only thing that is reviewed is the original request. *Defined as a call where, if it's seen, it happened, and there is no room for interpretation. Examples are non-judgement calls; Counter-Examples are judgement calls. Example, defense crossing. Example, two balls in the robot. Example, Secret Passage violation. Counter-Example, intentional tipping. Counter-Example, egregious behavior. Counter-Example, robot with ball bumps another ball out of the way or drives over it. Example, zone entry in 2014. You get the idea. |
#238
https://www.chiefdelphi.com/forums/s...2&postcount=49 |
#239
But really, shouldn't we be looking to make matches run quicker, with less down time? |
#240
The argument regarding additional time is not centered around the time to conduct the video review (hopefully there is a definite time cap on that), but rather the fact that blown calls lead to replayed matches. A single replay at a single event that did not change the outcome of a match does not change that factor in the least.
