Go to Post Dave Lavery, Lou Rosanio and Karthik are all Woodie Flowers winners this year. So mentors it seems like if ya want the WFA it might be a good idea to put on a kilt :) - Kyle [more]
Unread 24-08-2016, 22:04
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Versaplanetary Output Direction
I am going to change a question that might be a major Duh! moment.
Given a Versa Planetary with three stages a 5:1, a second 5;1, and a third 4:1 to make 100:1.
Now during competition season the ring gear on our 4:1 broke. For offseason repairs we replaced the 4:1 with a 3:1 and therefore we now have net 75:1 after repairs.
Now a question. Should we expect the direction of the output shaft to reverse with the change from 4:1 to 3:1?
I don't think so because that's not how planetary gears work. But I have been know to be wrong.
Thanks!
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 24-08-2016, 22:06
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Re: Versaplanetary Output Direction
Your assumption is correct. The output shaft will turn the same direction.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 24-08-2016, 22:09
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Is there any situation, short of running the motor the other way, where a VP would turn the other way?
Unread 24-08-2016, 22:10
Division by Pirates
No. All of the stages turn the same direction, regardless of how many there are or what gear ratio they are.
Unread 24-08-2016, 22:11
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
The output direction should not change. Just out of curiosity why did you run 3 stages to get a 100:1 reduction when you could have done it in 2 and saved the space, weight, and money the additional stage?
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 24-08-2016, 22:12
FRC #5202
Correct me if I'm wrong, but the 5 5 4 will be less prone to breakage than the 10 10.
Unread 24-08-2016, 22:16
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
To add onto this, the reason why this is true is because the VPs use the carrier plate as the output. In a planetary gearset where the ring gear is held still (like the VPs) the carrier plate will turn in the same direction as the pinion. Thus, no direction change.
Unread 25-08-2016, 10:09
Chris is me's Avatar
AKA: Pinecone
The 3-stage version is stronger - check the load ratings document to see how strength improves with more stages. That tiny 10:1 pinion can't take as much abuse as the 3:1 or 4:1 stage can.
Unread 25-08-2016, 16:49
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Although the 3 stage 100:1 reduction is stronger, it is more inefficient than a 100:1 using two 10:1 stages, right?
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 25-08-2016, 17:24
Correct. it is also worth noting that the 10:1 carrier plate fails at 100 N-M while a stalled 775pro with a 100:1 reduction will develop only 71 N-M at stall neglecting the inefficiencies of the stages needed to develop the 100:1 reduction. in other words, unless you use the dual input stage or use a motor and gearbox combination not recommended by vexpro it should not be possible to develop the torque necessary to break the ring gear on a VP.
Also as someone who managed to accidentally stall a 775pro into a 100 to 1 versa (10:1 and 10:1) this season, I can attest that the 775pro will fail before the versa will.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 25-08-2016, 18:06
AdamHeard's Avatar
Lead Mentor
You're able to develop more than the stall torque in FRC in two likely cases;
1) Reversing the voltage of the motor while still travling the other direction, this will results in a larger voltage across the motor than 12V, and generate higher torques (it stops being linear after the magnets saturate, unsure when that point is).
2) Dynamic and shock loads can cause brief torque spikes above the stall torque of the motor.
Unfortunately the above two make system sizing to avoid failure a little trickier, and for those reasons I would want to stay a good deal inside the Vexpro published ratings for the versaplanetaries to guarantee they keep running smoothly.
Voltage ramping (limiting the instantaneous rate of change of the speed controller output) can help alleviate the above two, but at the cost of acceleration time (likely negligible in most designs).
That being said, 330 has run them in quite large (but within spec) reductions the last two seasons on nearly all their systems with good success. I'm unsure if they do any voltage ramping or other tricks.
Unread 25-08-2016, 18:36
FRC #5202
Where is the 100 N-M stat located? From what I see, the load rating guide only includes safe ratios.
Or are you calculating the torque from the safe ratio?
Unread 25-08-2016, 20:01
The 100 N-M number is from page 13 of this sheet. Im assuming that the 1/2 inch hex or round shaft is being used causing the weakest link to be the carrier plate as the shaft fails at above the force the carrier plate can withstand.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 25-08-2016, 20:37
troy_dietz's Avatar
troy_dietz troy_dietz is online now
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz is on a distinguished road
The voltage on our arm motors is ramped. The motors are redundant, but we would likely have issues with our srimech if one was missing.
We have had issues with the carrier pins coming out occasionally, we're planning on welding them in place.
Since 2014, all of our arm VP's have led to an 5:1 chain reduction (the large yellow sprocket). I believe 2013 has a double chain reduction.
