Go to Post If there is water in the 2006 game, I will blame it on Gary. - dlavery [more]
Unread 25-08-2016, 11:15
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Why use a manifold?
Originally Posted by Jon Stratis View Post
...'ve seen teams block unused ports with epoxy or hot glue before, which just means that manifold is coming off the robot when the inspector sees it!
I am impressed that hot glue holds air.
