#31
Re: High Powered Targeting light on amazon
Why not just drive the first device off of the roborio directly? It's just digital outputs driving it. You would have to hack together a connection from roborio > Hero anyway, why not take a gadgeteer cable (which is the same as a talon encoder cable) cut one end off and put .1 connectors on it to hook to the digital out on roborio? |
#32
In fact, these breakouts might make it easier: http://www.ctr-electronics.com/breakoutmodule.html Last edited by marshall : 25-08-2016 at 11:41. |
#33
We used these.
We modified the flashlight to skip the control board and just power the light. We lathed down the aluminum enclosure to fit what we wanted. Since this had a current draw that took us over the limit for the VRM. We had to run this off this relay controlled by the RIO. We had some complaints about our light earlier in the season. So, as soon as the bot fired, it turn off its light and then the operator turned it on when he wanted. We couldn't just plug this into our RIO due to the high current draw. We just wanted to be perfectly safe! |
#34
You could attempt to buy or borrow one from another local team. They should be fairly common, given that they were the only way to do pneumatics before the PCM
#35
That's not true. We had relay slots we could use out of the crio and all other control systems I have used going back to the radio based ifi systems +10 years ago.
