Go to Post Truly good teasers should give people a good place to start guessing, while still leaving some mystery and uncertainty. - Travis Covington [more]
Unread 25-08-2016, 22:04
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: Why use a manifold?
Originally Posted by GeeTwo View Post
Based on some number crunching I did during build this year, it appeared that the fastest cylinder performance would be to have a large tank (at least twice and preferably three times as large as the cylinder capacity) on the working pressure side of the regulator, then feeding directly from the tank to the solenoid valve to the cylinder. We did not get to test this, as it turned out the valves we were using had much too low a cv for this to make a difference.
I can tell you from experience this is true. This is how we plumed our soccer ball kicker on our Breakaway bot and it made a big difference.
Unread 25-08-2016, 22:13
IndySam's Avatar
The other reason to use a manifold is the exhaust air exiting through the manifold makes a cool sound.
Unread 26-08-2016, 10:02
Michael Hill's Avatar
Truth. Coolness of sound is, by far, the most accurate figure of merit for any FIRST robot.
Unread 26-08-2016, 10:52
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
A little of topic but. Bimba, a great supporter of First and is also is sort of the standard of the cylinders that we use has published a handbook on pneumatic design. Sizing of cylinders included.
Unread 26-08-2016, 11:38
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Just to confirm GeeTwo and IndySam,
Attached is a photo of our 2014 Robot, where we used two pneumatic cylinders to shoot the ball.
This shot is a little blury due to the camera DOF at the solenoids, but if you look closely and follow the tubing, you will see that the output of the solenoid, there is about a 1" of tube ported directly to the cylinder. The opposite end of the cylinder was left open to atmosphere.
On the input end of the solenoid, you will see about a 6" piece of tubing, to the bottom of a storage tank. This was a dedicated low "working" pressure storage tank for the solenoid and cylinder. With his set up we were able to shoot just with pneumatics, and also be able to shoot back to back shots, needed for out two ball autonomous.
https://youtu.be/IOU_eZ6CrqI
The sooner we get behind schedule, the more time we have to catch up.
Unread 26-08-2016, 11:46
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
On our 2014 robot we used a pneumatic catapult. We ended up putting a large number of tanks on the working pressure side to assist. We also ended the season with higher CV solenoids than we started with due to performance issues.
One key thing we did was we started logging air pressure on the 120psi side, the working pressure (nominally 60), and at the piston. Key things we learned.
1) The regulator suffers from hysteresis and does not always return to the set point every time.
2) We could have a 30psi or greater pressure differential across the solenoid.
I may still have the data available if anyone is interested.
