Go to Post MR. KAMEN! TEAR DOWN THIS WALL! - Briansmithtown [more]
Unread 08-26-2016, 07:27 PM
galaxygaleas galaxygaleas is offline
AKA: Jillian
FRC #3229 (Hawktimus Prime)
Rookie Year: 2015
galaxygaleas is an unknown quantity at this point
Lightbulb Object Tracking Suggestions
Our team is looking to try something we've personally never implemented before, the object/vision tracking card that allows for better autonomous runs and hopefully easier handling. I personally don't know much about the process it takes and don't know where to start. I've been researching different chips I've heard of to complete the task but other than that would like some suggestions on the issue. What cards are recommended and how easy are they to implement into programming?
Unread 08-27-2016, 04:50 PM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Object Tracking Suggestions
Lots of teams use the Raspberry Pi or an Nvidia Jetson board.
The Pi is relatively easy to program on (in python, and it's easy to install the OpenCV bindings for python).
I don't have any experience with the Jetson but I assume it's more difficult to use than the Pi. However, the Jetson is also vastly more powerful.
The third option is an Android phone. A handful of teams used one last season. The advantage is that you get a high quality camera and a powerful processor in a single package. It's also easy to use OpenCV in Java. The caveat is that Android OpenCV doesn't use the GPU by default -- to enable it you need an Android with OpenCL support, and you need to use the T-API in native code (which is more difficult)
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 08-27-2016, 06:38 PM
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
I know 1296 used the Pixy cam this year. I've heard it's a little hard to set up, connecting to the RIO and everything, but it should be very straightforward from there.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
