Go to Post 2015 never happened - Chris is me [more]
Unread 27-08-2016, 16:50
euhlmann's Avatar
euhlmann euhlmann is online now
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Object Tracking Suggestions
Lots of teams use the Raspberry Pi or an Nvidia Jetson board.
The Pi is relatively easy to program on (in python, and it's easy to install the OpenCV bindings for python).
I don't have any experience with the Jetson but I assume it's more difficult to use than the Pi. However, the Jetson is also vastly more powerful.
The third option is an Android phone. A handful of teams used one last season. The advantage is that you get a high quality camera and a powerful processor in a single package. It's also easy to use OpenCV in Java. The caveat is that Android OpenCV doesn't use the GPU by default -- to enable it you need an Android with OpenCL support, and you need to use the T-API in native code (which is more difficult)
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 27-08-2016, 18:38
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
I know 1296 used the Pixy cam this year. I've heard it's a little hard to set up, connecting to the RIO and everything, but it should be very straightforward from there.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
