Go to Post I'm looking forward to January when things will slow down some! - Foster [more]
  #38   Spotlight this post!
Unread 29-08-2016, 16:41
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
Re: How are teams mounting drivetrain encoders on WCD?
Originally Posted by gc_coxen View Post
The plan has shifted to using 9mm belts on a direct c-c with the wcp side bearing blocks. My thought was utilizing feed forward as suggested by a teammate to minimize any slop. Is there a noticeable difference between mounting to the output shaft or rear wheel axle, specifically in regards to necessary programming to counter backlash/slop?
Properly tensioned timing belt runs have minimal backlash and will not require any code to compensate for play.
If you're going to use direct c-c, why bother using the WCP side bearing blocks? Teams have been very successful using flanged bearings directly in 0.125" and 0.100" wall tubes. The benefits of dropping the bearing blocks are lower weight, lower cost, slightly reduced tolerance-stackup and easier/more precise machining (circular holes vs rectangular cutouts).
Also, what size pulleys and wheels do you plan to use?
