Re: Using a 775pro in Dusty Conditions
Is power important or is it more weight reduction that you are wanting? If you wanted to reduce weight and don't need a lot of power a small sealed motor like a BAG motor could work. Last edited by pilleya : 30-08-2016 at 00:54. |
Let me brutally honest about this from our competition experience down at Kennedy in '13. They will not survive past the competition unless your motor enclosures are above excellent. See my link below about this.
https://www.youtube.com/watch?v=DaodHQC_MIo We had an enclosure that was large enough to allow for some air to move around our rs775s but you will not have that in a lunar/martian environment. In testing, we wrapped our motors in several different materials but even with sand we had thermal issues because heat was being generated quickly in those wrappings. We ended up going with enclosures that had dust barriers around the drive shaft. The encoders we used were also protected with an enclosure that was a bit taller if you look in the video. We had to replace 3-4 motors out of 6 because this material is so fine that it actually went through two military grade dust barriers and into the motor. I would recommend using CIMS if possible because if any of that dust gets in the rs motor it is done for. We even had melted fans in the motors. If we had the weight we would have went CIM motors for sure. The challenge is a lot harder than it looks. We qualified in 6th place I think which was the first time UNCC ever qualified. Also, do not get that stuff on your skin!!!! Clean your rover really well when you come out. |
Regolith simulant is also INCREDIBLY abrasive. I would be very surprised if a 775pro held up to it for more than a few minutes here and there. Last edited by Cory : 30-08-2016 at 14:45. |
Way back in 2007- 2009 when the Regolith competition was one of NASA's centennial challenges, myself and a couple other industry folks decided to enter a couple of robots in our free time. Ended up placing 2nd and 3rd.. We ended up right behind Paul back when he was at WPI doing robotics then (and now with BiteForce).
To the best of my memory, all of our drives were fully sealed, both motors and gear trains. Just like FRC we really wanted to keep our drivetrain as bullet-proof as possible. If I recall correctly we used fully sealed Maxon motors as well. I believe they were brushless as well however that part i am not remembering as well. Plus as Cory mentioned you really are not going to have the ability for convection to cool your motor out on the lunar surface. My thoughts that the 775pro would likely meet a relatively quick death with the amount of dust kicked up. To my knowledge, the simulant is designed if to have relatively sharp edged particles that would replicate the lunar surface and not the water eroded particles that we typically see here on earth and thus be much more abrasive than normal sand, dirt etc... Good luck! |
Thanks for the recommendation Aren. I'll be sure to do my research on brushless motors before buying anything. Do you have any motors in mind? |
#7
It did plow into a boulder and go right over it though! |
