Go to Post Now, everyone knows that Oompaloompas are like bunnies in that they have an insatiable desire to multiply, and the same can be said with Michigan teams (with all due respect) which are currently multiplying and filling that hand-shaped democratic kingdom with their honorable number. - Eugenia Gabrielov [more]
Unread 29-08-2016, 23:29
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Using a 775pro in Dusty Conditions
Since the 775pro is a fan cooled motor, is it possible to run it in very dusty conditions? For reference it would be used on a mining robot built for NASA's Robotic Mining Competition. The mining material is called regolith (not the horrible FRC kind) and it is made up of very small particles of volcanic ash called BP-1.
We are thinking about using a system of fans and filters to keep the motors cool and sealed. The logic behind using a 775pro or just a fan cooled motor in general is the weight savings vs. a cim motor for example.
So can a 775pro survive these conditions? Is this a stupid idea? Does anybody have any motor recommendations that would be better suited than the 775pro?
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns 2015/2016 Project Lead: Reveal Paper
Unread 29-08-2016, 23:35
Re: Using a 775pro in Dusty Conditions
Not a pro, but I have used a 775 (RS-775-18) in the same competition. Used drink cans (empty, of course, and missing one end...) around the back end of the motors and plenty of tape to seal the dust out. No motor problems, but the speed controller safeties gave us trouble... (not motor-related). This was in the drivetrain; I want to say I uploaded a photo to CD-Media some time ago of that robot. There was no cooling on the robot--remember that there is no air on the moon, so fans aren't exactly useful (FRC 2009 aside). Judges just might call ya on that.
I'm not sure I'd use a 775-Pro in that application, offhand, but if it seems to work out powerwise that might do the trick.
Unread 29-08-2016, 23:39
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
I think it would work, but it may not last long if dust stops the fan or impedes airflow. Motors will work if they're filled with dust, but they will probably run hotter. How fine is this dust? Maybe you could put a screen or filter over the 775's vents and just clean it every run. Is there anything electrically conductive in the dust?
True. I wonder what would happen if it stalled on the moon... Also, the temperature of the moon would help make up for the lack of cooling at night. In the day, not so much...
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 29-08-2016, 23:44
This is really, really fine dust. As in, tyvek suit, dust mask, and safety glasses just to enter the operation area (see next to my WAI photo), and a respirator if you're in there longer than a couple minutes. I don't remember the exact size, but that's pretty fine...
Oh, and the robots get vacuumed on exiting, trying to get all of the dust off or out. I don't think there's anything conductive, but it's hard to say for sure.
Unread 29-08-2016, 23:53
Team Role: Student
Rookie Year: 2016
In that case, I doubt it would do well. I think I've seen motors permanently damaged from fine sheet rock dust, but I have also seen some full of household dust at a pretty fine size that continued to work. I did once accidentally send a small amount of baking soda through a vacuum cleaner motor, and it survived. Still, I probably wouldn't try it without a filter. You don't want it to fail during a competition match/run.
Unread 29-08-2016, 23:57
I added a link to my previous post, but I'm not sure you'll be able to see the motor shields through the frame. They'll run, but you want 'em shielded pretty well.
Unread 30-08-2016, 00:12
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Thanks for all the advice Eric! Good to know there is precedent for something like this. We'll obviously do some testing before implementing anything.
The 775pro is just such a powerful motor for the weight that I think it's worth the trouble to filter and cool it. Given how fine the BP-1 is, would filtration even be possible? I haven't taken the time to look into that yet.
Also, NASA allows fan cooled motors despite the fact that there is virtually no atmosphere on the Moon/Mars. This is because NASA can afford much nicer motors than us
Unread 30-08-2016, 00:26
Aren_Hill's Avatar
Build Nifty Things
If I were you I would venture into brushless land, an Inrunner is already sealed, or an outrunner doesn't really care that much, but could be sealed without too much work.
-Aren
A guy who likes robots.
Unread 30-08-2016, 00:50
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Originally Posted by Ginger Power View Post
The 775pro is just such a powerful brushed motor for the weight that I think it's worth the trouble to filter and cool it.
If your looking to reduce weight a brushless inrunner will be more powerful for the same weight and will be sealed. The resources you need such as flashing brushless ESC's with SimonK is quite well documented and is reasonably straight forward.
Is power important or is it more weight reduction that you are wanting? If you wanted to reduce weight and don't need a lot of power a small sealed motor like a BAG motor could work.
Facebook
Unread 30-08-2016, 01:30
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Out of curiosity, would the ultra-fine grit get through the bearings? How would any motor be safe for long?
Unread 30-08-2016, 11:11
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
Let me brutally honest about this from our competition experience down at Kennedy in '13. They will not survive past the competition unless your motor enclosures are above excellent. See my link below about this.
https://www.youtube.com/watch?v=DaodHQC_MIo
We had an enclosure that was large enough to allow for some air to move around our rs775s but you will not have that in a lunar/martian environment. In testing, we wrapped our motors in several different materials but even with sand we had thermal issues because heat was being generated quickly in those wrappings. We ended up going with enclosures that had dust barriers around the drive shaft. The encoders we used were also protected with an enclosure that was a bit taller if you look in the video.
We had to replace 3-4 motors out of 6 because this material is so fine that it actually went through two military grade dust barriers and into the motor. I would recommend using CIMS if possible because if any of that dust gets in the rs motor it is done for. We even had melted fans in the motors. If we had the weight we would have went CIM motors for sure.
The challenge is a lot harder than it looks. We qualified in 6th place I think which was the first time UNCC ever qualified.
Also, do not get that stuff on your skin!!!! Clean your rover really well when you come out.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 30-08-2016, 11:52
Pneumonoultramicroscopicsilicovolcanoconiosis.
Be careful.
Unread 30-08-2016, 12:04
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is online now
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Be careful.
Do robots really get diseases from inhaling fine volcanic ash? Huh.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 30-08-2016, 12:34
Data Nerd
FRC #0079
Be careful.
Is this the disease you get if you try to pronounce that word?
Unread 30-08-2016, 14:22
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is online now
AKA: Alan Wells
FRC #1350 (Rambots)
That word is the longest word in the Oxford English Dictionary.
It isn't that hard to pronounce. You just have to break it up into parts:
pneumono + ultra + microscopic + silico + volcano + coniosis
Alternatively, you could just say silicosis, which is a synonymous term.
