Go to Post As my daughter said, you used to shut up your robot and send it away from home. Now you just suffocate it. - GaryVoshol [more]
Unread 30-08-2016, 14:42
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Using a 775pro in Dusty Conditions
Originally Posted by OccamzRazor View Post
We had an enclosure that was large enough to allow for some air to move around our rs775s but you will not have that in a lunar/martian environment.
As a point of reference, brushed motors wouldn't function on the moon at all, or would fail very quickly if they did. They can work on Mars because there's a thin atmosphere, but they cannot handle the vacuum on the moon. Outgassing of all the lubricants occurs, the brushes can be damaged (the presence of water vapor essentially lubricates the brush-commutator interface. Without it, damage rapidly occurs of graphite brushes), and the outgassing causes increased thermal load which cannot be transmitted to the surroundings well due to lack of atmosphere.
Regolith simulant is also INCREDIBLY abrasive. I would be very surprised if a 775pro held up to it for more than a few minutes here and there.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-08-2016, 15:20
kaliken kaliken is offline
294 Old Fart Mentor...
AKA: Ken S
kaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant future
Way back in 2007- 2009 when the Regolith competition was one of NASA's centennial challenges, myself and a couple other industry folks decided to enter a couple of robots in our free time. Ended up placing 2nd and 3rd.. We ended up right behind Paul back when he was at WPI doing robotics then (and now with BiteForce).
To the best of my memory, all of our drives were fully sealed, both motors and gear trains. Just like FRC we really wanted to keep our drivetrain as bullet-proof as possible. If I recall correctly we used fully sealed Maxon motors as well. I believe they were brushless as well however that part i am not remembering as well.
Plus as Cory mentioned you really are not going to have the ability for convection to cool your motor out on the lunar surface.
My thoughts that the 775pro would likely meet a relatively quick death with the amount of dust kicked up. To my knowledge, the simulant is designed if to have relatively sharp edged particles that would replicate the lunar surface and not the water eroded particles that we typically see here on earth and thus be much more abrasive than normal sand, dirt etc...
Good luck!
2010 World Champions! Newton Alliance Captain: Many thanks to 67 and 177 for the amazing ride
Unread 30-08-2016, 17:34
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Originally Posted by asid61 View Post
Out of curiosity, would the ultra-fine grit get through the bearings? How would any motor be safe for long?
The competition consists of two 10 minute runs and a 10 minutes practice run. Hardly enough time to ruin a sealed motor. I'm sure most motors within our price range would have trouble in the long run, but that's one of many reasons the Mars rovers cost a lot of money
Originally Posted by Aren_Hill View Post
If I were you I would venture into brushless land, an Inrunner is already sealed, or an outrunner doesn't really care that much, but could be sealed without too much work.
-Aren
Thanks for the recommendation Aren. I'll be sure to do my research on brushless motors before buying anything. Do you have any motors in mind?
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 30-08-2016, 18:19
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Pneumonoultramicroscopicsilicovolcanoconiosis.
Be careful.
Supercalifragilisticexpialidocious just seems so weak, now.
And I'll bet that Aren does have a brushless motor in mind. But it may have to stay there, for a while.
Richard Wallace
since 2003
Unread 31-08-2016, 10:11
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
We smoked 2 of ours after the first official run but we had practiced with them for many hours prior to that. We smelled something burning and we opened up the box to find that lovely burnt plastic smell. 20 minutes between the practice and first run was all it took for the regolith to make its way into the boxes and wreck a couple of the motors.
It did plow into a boulder and go right over it though!
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 31-08-2016, 10:59
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
But Supercalifragilisticexpialidocious has a song.
Unread 31-08-2016, 11:01
https://www.youtube.com/watch?v=HaQt8wNrrqw
Unread 31-08-2016, 12:45
Dum-diddle-iddle-iddle, dum-diddle-eye!
Dum-diddel-iddle-iddle, dum-diddle-eye!
Richard Wallace
since 2003
