#16
Re: [FRC Blog] 2017 FIRST Championships Allocations for Districts
I'm pretty surprised about that, since all waitlist teams from district areas would have fewer district points than the points teams. Either regional waitlist teams are doing well enough to pull up the average or district points aren't doing that a good a job of sending the best teams. I don't think you're being serious, but it's important to note that nobody else is talking about how many teams are at champs, just how to pick those ones (points based or lottery). The same number of teams are getting the "championship experience" either way. |
#18
FIRST is not preventing 2869 from attending the event, but they are going to make the chance of the 27th best team in Chesapeake more difficult than the 41st team in the PNW, even though CHS is 85% the roster count as PNW. I've accepted that someone has poured water all over my cereal, but they didn't have to pee in it too. |
#19
The decision to calculate the percentage based on teams only in the geographic region of your Champ definitely helps MI logistics-wise.
Without the change, MI would send about 411/3130*804 = 105 teams to NorthCMP, or more teams than at MSC the last couple years. With that change and the 10% one, it's only 79 teams qualifying, so MSC is not irrelevant in qualifying to NorthCMP. |
#20
And then you can consider which teams would apply for waitlist spots. While there are certainly exceptions, it's going to be the better funded teams, as attending champs is a rather expensive proposition. And it'll probably be the more confident teams, those that are confident they can build a decent robot and do well enough at champs to make a trip worthwhile (even if they are realists and realize the schedule or luck in playoffs can work against them). Now, think about all the regional teams you don't see at champs. Teams that were finalists (although there's less of that now with the wildcards), semifinalists, or quarterfinalists, all of which may be pretty decent - especially when you look at the different relative strengths of regionals. Just take a look at the 2014 Lake Superior regional playoffs for an example - every set except Semifinals 2 went to a third match, with so many close games that any alliance really could have won that event that year. So while any team can get in off the waitlist, there are enough good teams across FIRST, and enough psychology involved in spending that type of money, to suggest that we'll get some better teams than you might expect from it. |
#21
The district points system is not designed to send the top performing robots to CMP, it is designed to send the teams that earn the most points. Yes robot performance is where the bulk of the points are earned but awards earn points and there are bonuses for rookie and 2nd year teams. At the cutoff point the range of points is often quite small and winning just one award can make a difference of earning a CMP spot or not. |
#22
Say team A is above the points cutoff and team B is directly below it. If team A receives a waitlist spot, team B qualifies for Champs. While team A technically received a waitlist spot and team B earned a spot on district points, team B only earned their spot because team A received a waitlist spot. In this regard, I think it makes more sense to categorize team B as the waitlist team than team A because team B would not have earned a spot if it weren't for the waitlist. My hypothesis is that districts are much better than regionals at qualifying competitive teams for Champs. I think the waitlist picks up the slack with qualifying good regional teams who missed champs because they were not on the right alliance to win/make finals and didn't win a culture award. Many of these teams, if they were in a district, could have easily qualified for champs. |
#23
In what official record? I have no knowledge of any public record of this.
#25
Here is my recreation of how teams qualified. Note that it incorrectly includes DCMP winners as "District Points" spots. Distinguishing waitlist teams from district points teams was tough. If a district got X points spots, then I took the top X teams from that district who did not already qualify. The rest were included as waitlist teams. There was usually a pretty clear cut off point. |
#26
What is the predicted spots allocated for 2017 based off in the 2016 season? Because you have PNW going from 30 to 41 and then there is Indiana going from 9 to 10. Indiana has an 11% increase where PNW has about a 37% increase.
Are these increases based off of a projection of how many rookie teams will be added to the 2017 season? IN gained 0 teams last year total so is FIRST assuming IN will gain 0 teams again this year? I'm just curious how these were designated. Thanks ![]() |
#27
So it's using the exact same numbers as 2016, assuming no increase anywhere. The difference you note is the difference between norths champs and south champs. districts going to south champs are going to get bigger increases than districts going to north champs. |
#28
Anyway, if you think the CMP has the same purpose as a little league championship, you may want to read up a bit on what FIRST's goals are. However much you might want it to be about earning your way, FIRST doesn't want that. |
#30
Full Sarcasm Alert!: Can FIRST do us all a favor and send 3/4 of MI to half champs south? 201-60 = 141 and 88+60= 148. That'd make for a much better district distribution and would cause the same percentage increase of HalfChamps spots allocated to each district ![]() Last edited by logank013 : 09-01-2016 at 08:54 AM. Reason: Grammar... Does CD really expect me to Engrish Correctly? |
