Go to Post Fun and adrenaline make you waaaaaaaay better at robotics. Proven fact. - Matt Krass [more]
  #166   Spotlight this post!
Unread 02-09-2016, 14:51
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Re: [FRC Blog] FRC Events Being Posted and AMAA on FUN
Originally Posted by rwodonnell View Post
Yes. Unfortunately, the data from TBA that was easy for me only has city and state. When I imported them into the map, it stacks teams from the same city. If you click on the down arrow below the "teams.csv" layer, it will list all the teams that have a dot there. Cities like Middletown and Waterbury (from the teams you mentioned) and of course Boston (6 teams), Worcester (4 teams) and others will look like they just have one dot.
This does have the effect of improperly showing less team density in certain areas. If I could figure out how to have it put a number on those, or change the size of the dot, I would. If anyone has a CSV file of the teams in NE that includes a street address, I will import that and that should fix the problem, save for teams with the exact same street address (if there are any).
Thanks, that clears that up!
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
  #167   Spotlight this post!
Unread 02-09-2016, 14:55
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
If you put the data in google sheets, you can do the map marker and you'll have bubbles sized to the # of teams there. I recently downloaded Tableau (that's what the person who did the map for Michigan team density did and it looked great) to do the same there though, because with the google sheets map, it's "smallest" size is the continental US. Which is workable for mapping teams in Texas. probably not so much so NE. *EDIT* - here's a link to my google sheet for reference: https://docs.google.com/spreadsheets...5mQ/edit#gid=0 - it takes a long time to load because it basically does a search for every one of the cities
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
  #168   Spotlight this post!
Unread 02-09-2016, 19:53
rwodonnell rwodonnell is offline
AKA: Rick O'Donnell
FRC #2876 (Devilbotz)
rwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to behold
Thanks for the tip - that's a good way to go about it. The map I made is made from "Google My Maps". I hadn't make a map in a google sheet before, I will have to give that a try.
  #169   Spotlight this post!
Unread 04-09-2016, 19:28
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Does anyone have any info on LI, HVR or Montreal, such as when dates will be officially be posted?
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
  #170   Spotlight this post!
Unread 05-09-2016, 19:17
Division by Pirates
http://www.robotiquefirstquebec.org/...-de-robotique/
If this is accurate and my high school level French is correct, looks like Montreal is week 4.
  #171   Spotlight this post!
Unread 05-09-2016, 19:52
Professional Stat Padder
I guess they didn't get the memo that every event in the area is supposed to be week 3 this year. As much as we've been complaining in NY, Montreal teams have it even worse, having only the Montreal event to go to, and the only other driving distance event is hours away, across a border, and the next week. I bet TVR is going to get a good number of Montreal teams this year who used to compete for their second event in Ontario.
(2015-Present)
  #172   Spotlight this post!
Unread 06-09-2016, 07:55
logank013's Avatar
logank013 logank013 is offline
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
Any info on Queen City Regional information? I don't see it posted quite yet. Thanks
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
  #173   Spotlight this post!
Unread 06-09-2016, 10:46
guniv's Avatar
guniv guniv is offline
Communications / Business
AKA: Josh Witt
FRC #3966 (L&N STEMpunks)
guniv has a spectacular aura aboutguniv has a spectacular aura aboutguniv has a spectacular aura about
I emailed them a while back after Rocket City and Smoky Mountains ended up on the same week. They didn't offer what week it would be, but Queen City will be moving from Cincinnati to Dayton because their venue is unavailable, they told me.
2016 | World Championships - Media and Technology Innovation Award
2016 | Rocket City - Entrepreneurship Award | 2nd Place - Microsoft Imagine This
2015 | Smoky Mountains - Imagery Award
2014 | 3rd Place - Safety Animation Award
  #174   Spotlight this post!
Unread 06-09-2016, 15:13
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
I have a big feeling TVR and FLR are going to get flooded with a lot of Canadian teams. I look forward to it, as it helps provide diversity and bring in all sorts of new levels of competition. With both events already being so strong with everyone so evenly matched, this year may be even harder and closer of an event unless someone has a super outside the box design that reins supreme.
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
  #175   Spotlight this post!
Unread 07-09-2016, 12:17
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
FIM LSSU in Sault Ste. Marie has been posted.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
  #176   Spotlight this post!
Unread 07-09-2016, 13:42
Brian Maher's Avatar
Brian Maher Brian Maher is offline
Questionable Decisionmakers
FRC #2791 (Shaker Robotics), FRC #1257 (Parallel Universe)
Brian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond repute
FIM District - Lake Superior State University Event and Idaho Regional have been posted for week 5.
2016-present, Mentor, FRC 2791 - Shaker Robotics
2016: Tech Valley SF (5236, 2791, 3624) and Quality, Finger Lakes SF (5254, 2791, 2383), Battlecry@WPI Winner (195, 2791, 501), Robot Rumble Winner (2791, 195, 6463)
2016-present, Mentor, FRC 1257 - Parallel Universe
2016: Mount Olive Winner (1257, 5624, 1676), Bridgewater-Raritan Finalist (1257, 25, 3340, 555) and GP, MAR CMP Winner (225, 341, 1257), Archimedes SF (4003, 4564, 5842, 1257), IRI Invite
2012-2015, Student, FRC 1257 - Parallel Universe
2015: Mount Olive QF (1257, 1811, 1923) and Safety Award, North Brunswick Finalist (11, 193, 1257) and Team Spirit and Safety Awards
2014: Clifton Winner (1626, 869, 1257), MAR CMP QF (1257, 293, 303)
2013: TCNJ Safety Award
2012: Mount Olive QF (204, 303, 1257)
  #177   Spotlight this post!
Unread 07-09-2016, 14:02
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Was hoping Idaho would get moved to week 6 to facilitate more teams coming from Colorado & the SF Bay area. Last year the event hosted 30 teams with room for at least 12 more. Help fill the field... https://scontent-sea1-1.xx.fbcdn.net...548675_o.jp g
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
  #178   Spotlight this post!
Unread 07-09-2016, 16:04
TheBoulderite's Avatar
TheBoulderite TheBoulderite is offline
Director of Communications
AKA: Warren Bartlett
FRC #1619 (Up-A-Creek Robotics)
Rookie Year: 2015
TheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond repute
That's a shame it's Week 5. It'd be fun to come up there.
2015-now: 1619 (Up-A-Creek Robotics)
???: 2017 Utah Regional, ???: 2017 Colorado Regional
Thanks to all of our alliance partners over the years!
(1583, 1667, 937, 1332, 1158, 1348, 2543, 2261, 1777, 2240, 2036, 3648, 1410, 3200, 3807, 4550, 399, 2594, 1987, 4153, 624, 4334, 1730, 4593, 3618, 3026, 967, 4499, 3009, 1011, 525, 4028, 3352)
  #179   Spotlight this post!
Unread 07-09-2016, 21:55
Does anyone know when the Hudson valley event is, or how big of an event it's supposed to be?
  #180   Spotlight this post!
Unread 07-09-2016, 22:23
I heard a while back from someone on the regional planning committee that it was most likely going to be Week 4. For anyone who wants to go to it and TVR/FLR, get ready for good old back-to-back events
