| View Poll Results: What controller do you use to drive your bot? | |||
| Xbox 360 controller wireless |
1 | 0.60% |
| Xbox One controller wireless |
0 | 0% |
| Xbox 360 controller wired |
63 | 37.95% |
| Xbox One controller wired |
6 | 3.61% |
| Mad Catz Cyborg |
2 | 1.20% |
| Logitech Extreme 3D Pro |
49 | 29.52% |
| Other |
45 | 27.11% |
| Voters: 166. You may not vote on this poll | |||
Re: Poll: What do you use to control your bot?!?!
Usually use a xbox controller, but this year we decided to go gamecube. Don't do that. It like to get disconnected a lot.
Original GC controller via an adaptor, or one of those USB clones? The adapters can be a bit of a pain at times, but I've never had any issues with the USB clones.
Our standard setup for a few years now has been 2 Logitech Attack 3 joysticks for the driver. With this configuration, we've used tank, mecanum, and arcade drive layouts. Our operator previously used another Attack 3, but we found that insufficient for Stronghold, and we switched the operator to a Logitech Gamepad.
In the past, we have experimented with driving with a gamepad as well. At Gitchi Gummi Get Together, we had one driver on joysticks and one on gamepad (both drivers drove with both controllers at some point). They said that the joysticks were better (your mileage may vary). Personally, I prefer joysticks because they have a longer moment arm, and thus, finer control over acceleration. |
We use Logitech Gamepads (PS for PC controllers). They don't require a lot of energy to move, the drive team can put their hands where they want, and all the buttons are right there at your fingers (and we tend to use them).
I use a xbox one elite controller. Purely because I need the instant access to all the buttons on the fly. I drive the bot alone, and dont have an operator. I would not recommend this setup for anyone that isnt capable of doing 10 things at once under pressure and stress
. I linked an image of my latest control setup below. (note, the "activate boosters button" just flashes leds )![]() |
When I was the driver for Hotwire, I loved dual Logitech joysticks! They were the ambidextrous ones, not the 3D Pro. I felt that I got more control since joysticks give a larger range of motion than an Xbox-like controller.
Our current driver also uses dual joysticks. |
#7
One of the new smash ones with a mayflash adapter. Our drivers were both melee players and couldn't stand the clones.
#8
We have used the big Logitech joysticks from the kit some years, and an xbox 360 controller others (xbox slightly more commonly). What we use is largely a function of how the programmers and drivers would like it to work. (Trying to move the emphasis so that drivers are first on that.) Just Thursday, Chris converted T1GGR (2016 Stronghold robot) from xbox to joystick, because of flaky controller behavior at Red Stick Rumble. So far, just bench tests have been performed (it was raining Thursday, and our current practice area is outside, though under somewhat of a cover). I think he also switched from a tank style control (two joysticks' parallel axes) to arcade style control.
#9
Like many others, we've used the Logitech joysticks for years, as well as a Thrustmaster T.Flight Stick X. This year, when one of our logitech joysticks started to crap out on us, we looked around, and decided on the Mad Catz Cyborg, mainly because our driver for the past two years has been left handed, so we wanted something that could accommodate both hands as opposed to our Thrustmaster for last year. We weren't really concerned about the lack of buttons, as we generally prefer to make our own labeled control box using the TI Launchpad included in the kit. We've been fairly happy with the Mad Catz joystick, and we plan on 3D printing something to bolt in onto the driver station board, as it doesn't have much weight. The front gray portion of the joystick is removable by two little pins in the bottom, so we'll replace that with something boltable.
#10
Our driver uses two joysticks to drive while our opporator uses an Xbox 360 controller.
#11
Same. This seems like a common thing to do. |
#12
Though I am not entirely sure of what the controller is called (I am in class at the moment and don't really have it in front of me), it is sort of a PC controller. It behaves a lot like an Xbox 360 controller, but has a different layout in regards to button placement. Before that, we used two sort of flight-sticks that controlled like the joysticks on a controller.
#13
We've used PS4 controllers for the past few years.
#14
2 Logitech Attack 3 joysticks for driving and one Logitech Extreme 3D Pro for mechanisms.
#15
We tested out a DS3 controller with no luck. How were you able to get that working?
