Go to Post On day two of build season, I made the mistake of saying "We have six weeks, what could possibly go wrong?" - Zach Herbst [more]
Unread 07-09-2016, 10:55
ErikBoesen's Avatar
ErikBoesen ErikBoesen is offline
FRC #1418 (Vae Victis)
ErikBoesen has much to be proud ofErikBoesen has much to be proud ofErikBoesen has much to be proud ofErikBoesen has much to be proud ofErikBoesen has much to be proud ofErikBoesen has much to be proud ofErikBoesen has much to be proud ofErikBoesen has much to be proud of
Full release of FRC Dashboard
TL;DR: This $@#$@#$@#$@# is mother$@#$@#$@#$@#ing dope.
For the past two years our team has been using a web-based robot UI to control and monitor certain aspects of our robot, like our flashlight, autoaim, climbing winch, etc. etc. Here's a screenshot of our rebuilt 2016 interface (and the original from earlier this year, and 2015's interface), if you're curious. We've won a total of three Innovation in Control awards over the past two years for our UIs.
Anyway, at the end of the season, I decided to go through all the code and clean it up, remove unnecessary and unused code, and add lots of comments, in order to make something of a boilerplate for other teams to build their own UIs.
The result is FRC Dashboard, which I've designed with ease of modification in mind. It's built in HTML/CSS/JS, with a Python webserver. I've spun off most of the widgets and systems we used into addons which you can easily add on to your own UI. And as I said before, the code is full of lots of comments (and I mean lots) explaining everything to help you add and tweak your own widgets and code without wanting to pull out your hair.
You can get FRC Dashboard and all the addons I've prebuilt at this website.
(Or, here's the main GitHub repo, and a list of addons.)
This program is in (stable) beta, so if anyone has any suggestions, feel free to voice them in the comments, or start a pull request on GitHub. Thanks!
Unread 07-09-2016, 11:02
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
Re: Full release of FRC Dashboard
This is awesome. Great work!
Unread 14-09-2016, 00:13
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
While this is certainly a cool idea, I think it could benefit from better addon integration - copying and pasting code isn't really the best way to do addons IMO.
Self-contained addons could include all of their own html, css, and javascript code, and your dashboard could do the heavy lifting to import them instead of the user
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 14-09-2016, 08:11
ErikBoesen's Avatar
I've looked at doing this a lot of times, but I can't figure out a good way to do it while preserving the customizability of the addons.
Also, since most of the addons require adding a case to a switch statement, I haven't figured out how to begin.
Any ideas?
Unread 14-09-2016, 09:43
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Welcome to software design! Where you try to make sure to retain features while nailing things down into a concrete framework.
You can create an add-ons folder, and within that a folder for each add-on you want to load. In each add-on folder you put an html file with the add-on snippet, a css file, and a js file with the code.
Each js file could look like this
module.exports = {
   tag: "my-addon",
   init: function(htmlNode, etc) {
        // js code here
Then you could have some custom tags that people can add in their html
<!-- other dash stuff -->
<my-addon></my-addon>
and you can scan for these custom tags and if one matches an addon's tag, replace it with the addon (inject the html and css, then require() and call init)
Just an idea
