Please...no more steenkin' light!
A few years ago, FIRST inflicted us with a high tech solution to making it easy to identify alliances, the stinkin' light.
This year, much controversy pertained to the placement of the light. Despite the rules, many teams embedded their light inside their robot, making it hard to see from the stands and invalidating the purpose for the light. Many other teams followed the letter of the rule and had a more visible, and vulnerable, light. Our light, for instance, was almost completely demolished by the end of the competition season. The poor thing is held together by super-glue, duct tape, and tie wraps. The problems with the light are many. It is heavy. It is bulky and tall. In competitions where you have a low constraint of 14", the light may reduce your height constraint to 10" or lower. It consumes precious power and an extra relay. It requires effort to mount and wire it. The light is a very high tech, resource intensive solution to a simple problem. Many teams solved this same problem (robot identification and visibility) more effectively this year by putting a whip antenna flag on their bot. So my proposal is, why doesn't FIRST require us to use a flag instead of a steenkin' light? |
THE LIGHT IS THERE FOR SAFETY PURPOSES
derrrrrrrr it not only id's an alliance it shows the robot is on so people dont walk up to it and get hurt. |
Because the lights are just freakin cool.....
I'm sure FIRST will come up will a more defined set of rules on light placement next year... and these lights were actually smaller then lights in the past (2000, 2001, etc.).... If ya dont want the light broken dont put it in a high impact zone, we usually have our light in the center of the 'bot and i cant remember ever having a light broken (maybe in 2000 or 2001 once)A flag would be harder for people in the stands to identify alliances, ya cant miss the color of the light (even if teams did have in buried in their 'bot) I'm sure the lights will always be a part of FIRST robots... ![]() |
I thought it was hilarious were some teams placed their lights. I saw one team where their light was destroyed almost every match.
I'm all for the light. It actually does make it easier to identify MOST teams.
However, our team had bright red frame and 639 was in huge letters on sides and back upon a white background which was really easy to see. The rule I don't like is how the judges want numbers on 4 sides, as in the four sides AROUND the robot. For stackers, the actualy front side is not a very good place for the number. Reading the rules carefully, the number can be placed on any 4 sides at 90 degree intervals. The top is then a much better side for stackers yet most inspectors didn't seem to think so except one who went and READ THE RULES. I think 3 sides is plenty for identifying a robot, along with a light. It's not like the robtots are covered in styrofoam peanuts. |
#7
Best argument for the light is robot function.
No light= broken robot. Especially in this variety of when robots were enabled (depending on when the human player got out of the field) or if the robot tried to leave during autonomous the light helped tell the spectators as well as th edrive team what was going on (sort of) So I like the light. But more consistant placement rules would be nice. How about LED strings around the frame? Say 4 feet in the kit and 1 foot must be visible from any side of an unobstructed robot. Just a thought |
#8
I saw a team at SVR who was designed to go under the bar, but their light was on a spring-loaded hinge with protector bars around it, so when they went under the bar, the light was pushed down, and then it popped back up and swung back and forth a little. That was hella cool.
#10
The light has saved my life numerous times. Esp. while testing the auto mode. It's one of the few times when you don't want to go towards the light.
#11
Im pro-light. I weighed the 2002 light and then the 2003 light and found out that the 2003 light is about half the weight of the 2002 one. Also they really have improved the light a lot from those big bulky lights held in by hose clamps in 2000 to the little twist on light in 2003 that was definitely less annoying than in 2002.
#12
lights are good. plus, when you do demo's people think the light is cool looking. it gives it an extra effect
#13
The light is a necessity. It is extremely helpful in scouting situations; it helps identify robots when the team's number is way too small to see at a distance. Plus it makes the match a little more interesting if it causes problems.
#14
FIRST should more clearly mandate light visibility at the beginning of the season and then stick to it!
The challenge of the light placement should be looked at as just another "engineering opportunity" My vote - Keep the light (a light) |
#15
I agree that the light should stay. Flags are much more difficult to identify than a rotating light. You can't miss a light even if you wanted to. It also helped attract attention and keep the driver focused amidst the jumble of boxes. I don't know about other regionals, but our light shattered once when we were forced under the bar and FIRST replaced it for us.
| light visibility | Erinn888 | General Forum | 30 | 17-02-2003 15:56 |
| What color light is better on your robot | Rob Colatutto | General Forum | 24 | 11-09-2002 20:33 |
| About the light that need to be seen from four side | archiver | 2000 | 3 | 23-06-2002 23:01 |
| Important info about light | Jay Lundy | Technical Discussion | 10 | 12-04-2002 11:37 |
| How many posters does it take to change a lightbulb? | Brandon Martus | Chit-Chat | 7 | 22-02-2002 19:48 |
