Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
Unread 08-09-2016, 09:41
inorbert inorbert is online now
Build Captain and Driver
FRC #5811 (BONDS)
Team Role: Driver
Rookie Year: 2016
inorbert is an unknown quantity at this point
Uses of Lexan
My team (5811) has a sponsorer who is a plastics manufacturer; they allow us to have any scrap material we want so we have a stock pile of lexan in our shop. Last season we used it as guide pannels for our intake and decoration. I was wondering if lexan (or other plastics) can be used for more stuctural components in robot build
Sent from my LG-D851 using Tapatalk
Unread 08-09-2016, 09:53
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Re: Uses of Lexan
Lexan or polycarbonate is great stuff.
Check out release videos from past years. I remember Team 16 using polycarbonate in their arm in 2014.
https://www.youtube.com/watch?v=lcsi4zBwIjc
Hard to see, but at 12 seconds one can see their arm is clear.
A number of teams made their arms out of polycarbonate in 2016.
We made our arm supports out of 1/4" polycarbonate.
Its not as stiff as aluminum, but it's tough and bounces back.
Dave
Unread 08-09-2016, 10:08
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
Re: Uses of Lexan
We use Lexan for a lot of different parts on our bots. Good stuff. For structural components you need to ensure that they are thick enough or rigid enough for the application, which can add weight.
Unread 08-09-2016, 10:42
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Uses of Lexan
I would recommend looking at and contacting someone from 1714:
http://www.thebluealliance.com/team/1714/2012
They do not have a 2016 picture on Blue alliance, but there are pictures from several other years. They often build a "clear" robot.
FRC 703 also used to build a lot of chassis components out of Polycarbonate.
Lexan or polycarbonate is a wonderful material, and with proper techniques can be an incredibly useful material.
Many teams use the very thins stuff (under 1/16th and sometimes as thin as 0.020") for body panels with graphics. Well applied and designed body panels can make a robot get a new personality and have a much higher appearance of quality. when applied with Velcro, the panels offer easy access for pit crew, but a reasonable deterrent for other robots poking into your bot, or it getting hung up on field elements. The thinner you go, often the less robust.
Other good plastic parts are skids and sliders often made of UHMW or HDPE plastics. These can be good skids and guide for elements that strike field elements.
Unread 08-09-2016, 11:13
Chris is me's Avatar
AKA: Pinecone
Re: Uses of Lexan
The short version is yes. As IKE said, people from 1714 would be great to contact for more info (my HS team, haven't been in touch with them in awhile, hope y'all are doing great stuff, etc)
The key things to remember are that lexan is strong, but not particularly rigid. As a very rough approximation, to get a piece roughly as strong as an aluminum piece, you'll want to double the thickness (so a 1/4" lexan plate is roughly as strong and vaguely as rigid as a 1/8" aluminum plate). So for more structural pieces on a robot you'll end up using more 1/4" or even 3/8" lexan plate. Things like 1/8" lexan are great for lining surfaces supported by other materials (i.e. to form a flat area between two aluminum tubes, etc). 1/8" lexan can also be used for gussets but they do tend to be a bit weaker, so 1/4" or 3/16" lexan gussets are a safer bet.
The best use for structural lexan is in over-the-bumper manipulator components that deal with impacts from other robots. Things such as intakes, defense manipulators from this year, etc. The elastic deformability of lexan helps absorb the energy from impacts and prevents permanent bending in a mechanism that would otherwise bend if made from thin wall aluminum. Lots of teams used lexan in 2014 ball intakes extensively.
Unread 08-09-2016, 11:42
SeeleySWS's Avatar
SeeleySWS SeeleySWS is offline
Person To Blame
AKA: Spencer Seeley
FRC #3688 (The Norsemen)
Team Role: Operator
SeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud ofSeeleySWS has much to be proud of
Re: Uses of Lexan
Our team built a lexan bender (toaster wire, plywood, wiring and hinges) and were able to make a lot with it. Our intake's guides were bent lexan, our upper electronics board was held up by bent lexan and our bridge that held our camera and shooter sensors was made of bent lexan. Good stuff! If you want to prototype you can use cardboard...
Unread 08-09-2016, 11:56
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
Re: Uses of Lexan
We used lexan for the claw of our catapult this year as well as for the guides to slide the portcullis up.
461 Westside Boiler Invasion
45 Technokats
Unread 08-09-2016, 12:19
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Uses of Lexan
Lexan is great. We used it structurally on our intake arm, and later on we used Lexan disks over sprockets to prevent the robot treads from derailing.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 08-09-2016, 13:44
Levi Madden's Avatar
Levi Madden Levi Madden is offline
Student
FRC #1987
Levi Madden is on a distinguished road
Re: Uses of Lexan
Lexan has many uses, we used it this year for our electronics boards, the fact that it's clear really helped when having to see inside the robot. We also used it as our sponsor board, easy removal when attached with velcro. Really anything that you want a large surface area but don't mind a little bit of flexibility, lexan will work for, and the transparency is a nice bonus.
Unread 08-09-2016, 13:45
ns3517's Avatar
ns3517 ns3517 is online now
FRC #0316 (Lunatecs)
ns3517 will become famous soon enough
Re: Uses of Lexan
Polycarbonate is a fantastic material! I like to use it for some gussets, also it can be used a bunch in prototyping. Like other people have said its good for intakes as well. In my experience it's been better to use in prototyping because it's much faster and easier to form and build with then sheet metal.
Unread 08-09-2016, 13:48
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
jimbo493 is on a distinguished road
Re: Uses of Lexan
We actually used Lexan to rebuild our shooter deck for worlds this year, it was originally made of 1/8 inch aluminum, then to save weight and make it stronger(more resilient to impact) we made it of Lexan that was CNC milled exactly the same as the Aluminium, worked really well
FTC Student 2011-2012 FRC Student 2012-2016
FIRST Alum/Quasi-Mentor 2016-present
Unread 08-09-2016, 13:53
jweston's Avatar
jweston jweston is offline
FRC #1124 (The Überbots)
Rookie Year: 2015
jweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to beholdjweston is a splendid one to behold
Re: Uses of Lexan
Lucky you! Lexan is wonderful stuff. Strong relative to its mass. Our team has found it very useful for protecting electronics. I'm sure your team will discover all sorts of ways to put it to good use.
Unread 08-09-2016, 15:16
TedG's Avatar
TedG TedG is offline
CAD, Design & Graphics Support
AKA: Team supporter and enthusiast
FRC #0133 (BERT 133)
TedG will become famous soon enough
Re: Uses of Lexan
Yes as others have mentioned, Lexan is good, strong stuff.
All kinds of uses, the thickness depends on your use for it.
The thicker stuff (.375") can be drilled and tapped at the face or edges to take a 10-32 screw (as an example) to fasten to.
.25" can be drilled and tapped on the face.
The 1/16" is great for guards and graphics, we use Velcro for stuff like that so we can take it off when working on the robot.
Bonny Eagle Robotics Team - BERT 133
2009-2010: Mentor, 2010-2013 Advisor/Mentor, 2013-Present: Mentor/Cad & Graphics Support
2010 - GSR: Excellence in Website Design
2011 - GSR: Motorola Quality Award
2012 - Mainely Spirit: Spirit Award, Human Player Award- GSR: Gracious Professionalism Award, Quarterfinalist- Beantown Blitz: Finalist
2013 - Mainely Spirit: Sportsmanship Award- GSR: Semifinalist, Woodie Flowers Award- PTR: Semifinalist- Beantown Blitz: Semifinalist
2014 - GSD: Spirit Award, 5th seed, Semi Finalists- PTD: 2nd seed, Finalists
2015 - Safety Animation 1st Place Award, PTD: Excellence in Engineering Award, 8th seed, Finalists, UNHD: Spirit Award, 9th seed, 6th seed Finalist Alliance Captain; Event Winner
2016 - NSD: Industrial Design Award, 3rd seed, Semifinalist- PTD: Excellence in Engineering Award, 2nd seed, Event Winner
Opinions expressed here are mine alone, and not necessarily of the team.
Unread 08-09-2016, 15:48
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Uses of Lexan
Obligatory reminder to make sure you're using polycarbonate/Lexan/Makrolon and not acrylic/Plexiglas/Lucite. Polycarbonate is probably the second most useful robot building material after aluminum. I consider it to be more versatile because it's easier to machine on the fly (less setup required). There are hundreds of uses for it even if your main robot frame is aluminum.
Unread 08-09-2016, 16:09
jgerstein jgerstein is offline
FRC #1257 (Parallel Universe)
jgerstein is a splendid one to beholdjgerstein is a splendid one to beholdjgerstein is a splendid one to beholdjgerstein is a splendid one to beholdjgerstein is a splendid one to beholdjgerstein is a splendid one to beholdjgerstein is a splendid one to beholdjgerstein is a splendid one to behold
Re: Uses of Lexan
1257 uses a lot of Lexan/polycarbonate. In addition to some of the uses others have mentioned, our primary construction method for the past two years has been aluminum tubing with 1/4" polycarbonate gussets.
