Go to Post Besides, all the FIRSTers that I know - are children at heart. - JaneYoung [more]
Unread 08-09-2016, 16:26
niklas674's Avatar
niklas674 niklas674 is offline
Team 701 CAD Leader
FRC #0701 (Robovikes)
Team Role: CAD
Rookie Year: 2015
niklas674 is just really niceniklas674 is just really niceniklas674 is just really niceniklas674 is just really niceniklas674 is just really nice
Re: Uses of Lexan
Team 701 generally use lexan for prototyping. We also use it for covers for pieces that do not need to be exposed like the top of our shooter where the gears are.
My views do not represent the views of my team
Unread 08-09-2016, 16:55
Bill Klein Bill Klein is offline
FRC #3688 (Norsemen Robotics)
Bill Klein is a jewel in the roughBill Klein is a jewel in the roughBill Klein is a jewel in the roughBill Klein is a jewel in the rough
Re: Uses of Lexan
Originally Posted by SeeleySWS View Post
Our team built a lexan bender (toaster wire, plywood, wiring and hinges) and were able to make a lot with it. Our intake's guides were bent lexan, our upper electronics board was held up by bent lexan and our bridge that held our camera and shooter sensors was made of bent lexan. Good stuff! If you want to prototype you can use cardboard...
To add to Spencer's comment: The unit is portable (just a few lbs in weight without the battery) and is powered with one of our old 12 volt batteries. We take it to competitions and have assisted other teams needing a straight bend in their lexan. Simple and practical
Unread 08-09-2016, 20:19
kaliken kaliken is offline
294 Old Fart Mentor...
AKA: Ken S
kaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant future
Re: Uses of Lexan
Do you happen to have a picture of it or a diagram of it? Your bender sounds like a great addition to any team!
2010 World Champions! Newton Alliance Captain: Many thanks to 67 and 177 for the amazing ride
Unread 08-09-2016, 20:30
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is online now
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Re: Uses of Lexan
We used lexan a lot this year due to a lexan sponsor. A lot of our robot was clear including rails for the portcullis, actuators for the cheval, a belly pan for electronics, and the ball guidance system. I really like it as a material (it looks cool). For bending, we used a heat gun, which I don't recommend, but it was the only way.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 08-09-2016, 20:34
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Uses of Lexan
We had great success using 1/4" & 1/2" lexan for out catapult. Its very easy to work with which allowed us to build our catapult during one of our events with our pit bandsaw.
1058 PVC Pirates 2016 - xxxx
Unread 08-09-2016, 20:38
TAlholm's Avatar
TAlholm TAlholm is offline
Mainely CAD
AKA: Tim Alholm
TAlholm is just really niceTAlholm is just really niceTAlholm is just really niceTAlholm is just really nice
Re: Uses of Lexan
I used to use polycarb or lexan as much as possible when making guards for components and other low stress structures. Although it didn't make its way onto 1991's robot, this past year I had made a sturdy scissor lift out of lexan and plastic bolts. I believe the weight of the scissor lift itself was between 1 and 2 lbs. Granted, the entire climbing mechansim was over 5 lbs.
Polycarb and lexan are very strong, and after talking with 4061 (I believe) at worlds, it makes a good amount of sense to use it for arms of an intake or other extending components. Mainly due to the flexibilty of the material, and unlike aluminum it usually goes back to its original shape.
(Just be sure to use lexan or polycarb, and not acrylic. It ends poorly if you try and bend it)
FRC Team 1991 (2013 - 2016) - Head of Design / Head of Scouting
Don't trust me to cut down a straight line, unless it's on an automated router or mill.
Unread 08-09-2016, 21:43
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Re: Uses of Lexan
Originally Posted by inorbert View Post
My team (5811) has a sponsorer who is a plastics manufacturer; they allow us to have any scrap material we want so we have a stock pile of lexan in our shop. Last season we used it as guide pannels for our intake and decoration. I was wondering if lexan (or other plastics) can be used for more stuctural components in robot build
We've used polycarbonate in a lot of ways people have already said to good effect, and it's likely the plastic you'll want in main body structural situations (if you want a plastic). But since you're talking about plastics in general, I'll bring up another one: polypropylene.
Polycarb certainly beats polypro in terms of most structural members and loaded applications, but that doesn't mean it's useless beyond paneling. It can take weight with the right shape and volume: you've sat in quite a few polypropylene chairs, and we love to use it for battery boxes in awkward places. It has good toughness and impact strength and is less dense than polycarb--the main limitation is its reduced stiffness. Still, that can make it great for some over-the-bumper end effectors. We used it for our claw an minibot deployer in 2011 (for a regional win as AC2). We rammed the polypro V straight into the minibot pole all season and got the claw bashed up and dragged around with no trouble. Other uses include drivetrain skids (for getting over bumps), game piece ramps (it's slippery), and flexible brackets and guards (nice when you need some flex tolerance). Basically anytime we're about to use polycarb we stop and think 'can it be pro?' since polypro is lighter by volume.
Other novel-ish uses of plastics:
I'm not sure anyone has mentioned pillow blocks, but depending on how your axles are loaded there are a number of plastic options. We've used acetal (polyoxymethylene aka delrin) for end effector blocks before. Really want to analyze and test your loads here, though. We've also used acetal for larger jobs, namely the white skids used to slide up the pyramid in 2013.
Unread 08-09-2016, 21:52
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: Uses of Lexan
Not exactly structural, but we used polycarbonate this year as guides for our conveyor (easier to see when zoomed in), which also served to center the ball for the shooter. We used a heat gun to bend the pieces and the distance between them when attached to the robot was slightly smaller than width of the boulder where the guides gripped it, so the ball was slightly compressed while it was being held there. The flexibility of the polycarbonate gave us a firm grip that hugged the ball really nicely. The guides were 1/4" at one point, can't remember if that was the final thickness used or not.
Other uses of polycarb on this year's robot were chain guards, CDF manipulator (linkages on the bottom of the intake), bellypan, sides of our winch spools, and the top of our conveyor (added to block the ball from flying up and out of the robot after being grabbed).
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 09-09-2016, 00:25
Jonny_Jee's Avatar
Jonny_Jee Jonny_Jee is offline
FRC #2085 (Robodogs)
Jonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to behold
Re: Uses of Lexan
In 2010, my older sibling tried to make swerve drive module housing out of Acetal Copolymer Delrin plastic. Unfortunately, it was never used in competition.
Unread 09-09-2016, 00:56
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Re: Uses of Lexan
Originally Posted by IKE View Post
I would recommend looking at and contacting someone from 1714:
http://www.thebluealliance.com/team/1714/2012
When I saw the thread, my first thought was to MORE Robotics. Incredible team that competes at a very high level every season - and the clear robots they produce are fantastic pieces of engineering!
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 09-09-2016, 01:20
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Uses of Lexan
Originally Posted by cgmv123 View Post
Obligatory reminder to make sure you're using polycarbonate/Lexan/Makrolon and not acrylic/Plexiglas/Lucite
To be fair, there's really no mistaking the two. Polycarbonate is nigh-indestructible and will bend easily, while acrylic tends to crack/shatter if you so much as look at it wrong.
"The breakfast of champions!"
Unread 09-09-2016, 06:46
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: Uses of Lexan
Boom!
Unread 09-09-2016, 09:45
inorbert inorbert is online now
Build Captain and Driver
FRC #5811 (BONDS)
Team Role: Driver
Rookie Year: 2016
inorbert is an unknown quantity at this point
Thank you everyone for all the ideas and information, it is so helpful.
Sent from my LG-D851 using Tapatalk
Unread 09-09-2016, 15:39
Re: Uses of Lexan
Photo is posted. Thanks Rob Chapman for the pic and details.
https://www.chiefdelphi.com/media/photos/43953?
Search Youtube for "acrylic bender" and many tutorials come up. Most are 2-3 feet long and are attached to a variable power supply. Since we didn't have a variable power supply, however, the length was determined experimentally using our available DC voltage (12V robot batteries).
It's about 17 inches clip-to-clip.
The 20-gauge nichrome wire was sourced on eBay.
The circuit should be fused for 20 amps.
The one we made was modeled after this one:
https://www.youtube.com/watch?v=XveHMbzbyYQ
Unread 09-09-2016, 15:42
AKA: Ken S
Re: Uses of Lexan
This is great! Thanks so much for taking the time to post this. I would think this could help out lots of teams.
