Go to Post FIRST is our lever and the mentors are the fulcrum. - Daniel Brim [more]
Unread 09-14-2016, 02:07 PM
ttnn58 ttnn58 is offline
FRC #4586
ttnn58 is an unknown quantity at this point
custom button panel
hi!
my team is trying to build a custom button panel to control our robot, and we have some questions:
- i have read somewhere that the button panel is made of some kind of I/O microcontroller with buttons connected to it. is there a specific one we must use? because we have a microcontroller in our lab (i can't remember his name) which can be used as HID.
- how do we make our program to "read" this kind of input? (we use java)
thanks in advance!
Unread 09-14-2016, 02:23 PM
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: custom button panel
Assuming you don't use FRC rule breaking space magic, you'll most likely just be building a joystick with no axes. You can use the TI Launchpad you received in your 2015 KOP, instructions here: http://processors.wiki.ti.com/index.php/MSP430_LaunchPad_Operator_Interface_for_FIRST_Robo tics_Competition. You can then read it from code just like any other joystick button. You don't have to use this one, any HID compliant joystick will work. This one just has FRC support.
Side note: You can read from autonomous, it just reads the last joystick value right before autonomous begins.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 09-14-2016, 02:40 PM
FRC #4586
no axes indeed XD
but we won't use this one, i think we don't have it anymore.
we have some kind of prototyping kit.
if the comuputer can read the signal from the device, the robot code will just "find" it?
or we need another software for it?
Unread 09-14-2016, 03:16 PM
FRC #4586
UPDATE: the microcontroller we have is CY8CKIT-003 PSoC® 3 FirstTouch™ Starter Kit
http://www.cypress.com/documentation...ch-starter-kit
Unread 09-14-2016, 03:26 PM
Bkeeneykid's Avatar
AKA: Devin Keeney
Team Role: Student
Rookie Year: 2015
This one is much harder to work with. The basics is the board that you connect your buttons to acts just like a joystick. You then load special software/firmware onto the board itself, but the computer you plug it into basically sees it as just another joystick. I have this specific board, but I don't know if it can act like a HID joystick. A relatively cheap option is the Teensy boards, which are easily programmed using Arduino and can show up as a joystick without much effort.
Unread 09-14-2016, 03:33 PM
FRC #4586
you have to write a special software, or the comupter just sees the inputs?
and i am pretty sure it can act like an HID, we have it because it was used for a simmilar purpose.
and thanks for the help!
Unread 09-14-2016, 03:34 PM
Bkeeneykid's Avatar
AKA: Devin Keeney
Team Role: Student
Rookie Year: 2015
The computer has no special software. All the custom software that makes it reads the buttons is on the micro processor. Again, I don't have any experience with PSoC boards at all, so I can't help with programming that.
Unread 09-14-2016, 03:43 PM
FRC #4586
ok.
thank you very much for your guidance!
Unread 09-14-2016, 03:48 PM
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
If you have an arduino there is a software called unojoy that uses an arduino board and acts as a joystick.
461 Westside Boiler Invasion
45 Technokats
Unread 09-14-2016, 09:18 PM
eStop Robotics's Avatar
eStop Robotics eStop Robotics is offline
Partner, eStop Robotics LLC
AKA: Joe Troy
eStop Robotics has a spectacular aura abouteStop Robotics has a spectacular aura abouteStop Robotics has a spectacular aura about
hi!
thanks in advance!
You may find the Custom Control Interface (CCI) from eStop Robotics LLC to be a good simple solution to your "custom button panel" project.
The CCI requires no additional software and integrates easily with the FRC supported programming environments.
You can find more information on the following page at eStop Robotics:
https://www.estoprobotics.com/estore...d&productId=33
Unread 09-14-2016, 10:44 PM
Bkeeneykid's Avatar
AKA: Devin Keeney
Team Role: Student
Rookie Year: 2015
Interesting product, from a company I've not heard of yet. One concern, there doesn't seem to be many button inputs. If you do a autonomous switcher, that can be 5 inputs all by itself. Is there any way of increasing this? Also, do you have any way of doing the outputs in WPIlib like the MSP430 can?
Unread 09-14-2016, 10:46 PM
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Can't speak to this product, but eStop makes some pretty neat stuff. We used one of their battery hold-downs this season and loved it.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 09-15-2016, 12:32 AM
FRC #4586
thanks for the recommendation!
but i think that if we will buy a new controller it will be an arudino or an msp430 because they are cheaper (the msp430 is in first choice for 20 credits, arduino is about 25$) and they have more I/O us to use.
anyone here is familiar with this kind of project and i can contact to him if i need any further help?
thank you very much guys!
Unread 09-15-2016, 07:16 AM
jSchnitz's Avatar
jSchnitz jSchnitz is offline
Lead Programmer, Operator
AKA: Jacob Schnitzlein
FRC #1986 (Team Titanium)
jSchnitz is on a distinguished road
I'll second the eStop CCI board, we've used it for the past 4 or so years on all our button boxes. It's incredibly easy, no need to do anything with the board besides plug it into a computer.
I would recommend the Dashboard be used for autonomous switching - it saves physical space on the custom button box as well as button inputs. Also if you decide to add an autonomous mode (or 24), it's easier to add an option virtually than physically.
2016: Kansas City: Winner, Industrial Design Award. Smoky Mountains: Finalist, Engineering Inspiration Award. Archimedes Division: Winner, Industrial Design Award. FRC Dean's List Finalist
2015: Arkansas: Finalist, Quality Award. St. Louis: Winner, Industrial Design Award. Queen City: Winner, Quality Award. Carver Division: Quarterfinalist. FTC Dean's List Finalist
2014: Central Illinois: Winner, Chairman's Award. Kansas City: Winner, Innovation in Control Award. Newton Division: Semifinalist, Industrial Design Award.
Unread 09-15-2016, 08:19 AM
Bkeeneykid's Avatar
AKA: Devin Keeney
Team Role: Student
Rookie Year: 2015
Yeah sure, you have a crap ton of autonomous modes. In the past, we've found issues with the dashboard not loading in time for us to select autonomous modes. I'll check this option out, but I really prefer a physical switch, which has less points of error (for us).
