Go to Post So why are we trying to go to Mars? It's because it's bigger, better, and bolder. Doing what nearly no other team can do, and defying all those who say it can't be done. That reward is a lot more than 9 points. - Mike [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 16-09-2016, 12:36
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
pynetworktables - change IP address after initialization
I know this is probably a weird request. I'm working on an application that will relay I/O between our operator interface control board and the robot.
I want to add functionality to change the robot address because I will often switch to using a simulator (localhost) and our robot (roborio-4901-frc.local). I don't want to have to restart the application to do this.
Here's how the code starts up the network table service:
NetworkTable.setIPAddress(address)
NetworkTable.setClientMode()
NetworkTable.setWriteFlushPeriod(flushPeriod=flush _period)
NetworkTable.initialize()
What happens if I call NetworkTable.setIPAddress() after initialize is called? Can I reinitialize?
Thanks,
Ryan Nazaretian
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 16-09-2016, 13:31
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: pynetworktables - change IP address after initialization
If it implements NetworkTable.shutdown() as the C++ ntcore api does, then yes. Call shutdown, then set the address, then initialize again.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 16-09-2016, 14:21
RyanN's Avatar
RyanN
It doesn't. Thanks though.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 16-09-2016, 14:27
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
I'm anticipating rewriting NetworkTables in the style of ntcore before the start of the 2017 season, so it'll be there then.
Unread 16-09-2016, 14:49
RyanN's Avatar
RyanN
Thanks for the information. I'll pick around with the code and figure out a way to accomplish this.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 28-10-2016, 10:04
RyanN's Avatar
RyanN
virtuald has the support integrated now.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
