Talon to Talon SRX Necessary?
Our team has 4 Talons that we use for the drivetrain, and victors that we use for other motors. I saw the new motor controllers and wondered if it is a good idea to upgrade, or if what we have right now is fine. We probably would not use any special features like built in closed-loop control or can, so those features don't matter that much. The Victor SP looked like a good option to upgrade to as well.
Re: Talon to Talon SRX Necessary?
I'd go with the VictorSP. They're basically the same as the Talon but with better packaging and mounting options.
I would assert that there is no reason to change from a Talon to a Spark or Victor SP that justifies the cost.
+1 - apart from the form factor and weight (both minor improvements), there is no real difference. We plan to continue running our SRs on competition robots until they change the rules, and on non-competition robots until they release the smoke.
However, when I'm purchasing new motor controllers for a new robot, below is the model I intend to follow: I will tend to use the VictorSPs for the drivetrain motors based off of the cross the road electronics testing. It appears to offer the least resistance between the battery and the motor. But this difference is not something I'd expect to be perceivable in most cases. I will use the Spark for general purpose manipulators. It's the cheapest of the ones that I trust, allows for forward/reverse limit switches, and is a reasonable footprint. In 2016s case, we used it to extend our collect, collect the boulders, actuate our shooting mechanism, and actuate our CDF manipulators. I will use the Talon SRX if we have a manipulator that we want to have any kind of closed loop control/sensor feedback on. In 2016's case that was our flywheel. |
