Go to Post "What's this on the floor? 'Team 71 2005 strategy and design notebook'?" DRAT! I better call Bill and get this in the mail. - Gary Dillard [more]
Unread 17-09-2016, 16:14
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Does the RoboRio have mounting holes?
Does the RoboRio have mounting holes on the bottom? Cant seem to find any drawings online.
Unread 17-09-2016, 16:18
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Re: Does the RoboRio have mounting holes?
Per the manual, it has four 4-40 screw holes.
Check out page 30.
http://www.ni.com/pdf/manuals/374474a.pdf
Unread 17-09-2016, 16:19
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Yes, it has 4 threaded inserts on the bottom, as described on page 24 of the user manual located here: https://decibel.ni.com/content/servl...r%20Manual.pdf
There are also CAD drawings of the RoboRio available and linked from this page: https://decibel.ni.com/content/docs/DOC-30419
2016: Lake Superior WFFA
Unread 17-09-2016, 16:23
Team Role: CAD
Rookie Year: 2015
Check out page 30.
I see, thanks! The holes are modeled in the CAD, but I wasn't sure if they were for mounting or not since they are so small.
Unread 17-09-2016, 16:37
FRC #5202
I haven't used them, but their small size makes me wary about using them. I would honestly prefer to use zipties.
Unread 17-09-2016, 16:42
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
We've used them before. They work fine and look nice and neat. After all, your roboRIO should not be experiencing too much force anyways. Zip ties are still more convenient though, and you should just use them if you don't care too much about appearances.
Unread 17-09-2016, 19:06
FrisbeeFunTime FrisbeeFunTime is offline
Rookie Year: 2015
FrisbeeFunTime is an unknown quantity at this point
I have used them before and they work really well. I know for a fact we used them to mount it on our 2015 robot, in fact we only used 3 and it was still solid as could be. I do believe we used them on our 2016 robot also but im not 100% sure on that one.
Unread 17-09-2016, 19:30
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
We've used both the zip tie mounts and the screw mounts. Either works but the zip tie mounts trends to be easier to work with.
Unread 21-09-2016, 21:32
AManWithManyHat AManWithManyHat is offline
FRC #5885
AManWithManyHat is an unknown quantity at this point
I wouldn't recommend using them in all honesty, you can secure it very easily with zip ties and some Velcro on the bottom. It's really unnecessary to screw them in.
Unread 21-09-2016, 21:42
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
While it may not be necessary for operation the robo Rio being complete secure allows wiring to be kept neater. I also like putting rubber grommets under the Rio to reduce shock a little bit. It's probably just me over doing it but in all reality its a very expensive part that I want to last for a while so the way I see it why not take an extra 10 minutes to attach it more securely.
Unread 21-09-2016, 21:44
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
They are secure, but difficult to use in that you need access to the back side of the rio to put the screws in. For that reason, 115 used velcro or dual-lock all years except 2015 that I was on the team (and long before then as well). Having to flip over the robot to make sure the screws aren't loose sucks.
Unread 22-09-2016, 11:11
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
The holes on the back are designed to securely hold roboRIO, so feel free to use it. As others have already pointed out, the cable tie slots are there as an alternative and we see plenty of teams using heavy duty velcro or adhesive tape. Though the tape can make a mess if you need to remove roboRIO as the adhesive can be very strong.
Unread 23-09-2016, 15:18
messer5740's Avatar
messer5740 messer5740 is online now
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Heavy duty Velcro works wonders when mounting the Rio. It is much easier to attach and remove, and I would suggest using screw mounts only when you mount the Rio on a vertical plane plain such as in Recycle Rush elevator bots without very much chassis space to have a Rio.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 23-09-2016, 15:20
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Instead of Velcro, I recommend 3M Dual-Lock. It's a really strong plastic Velcro-like fastener, and it comes in the KOP.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 23-09-2016, 15:24
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
Oh well that's exactly what we use we just call it Velcro where I'm from
